timing belt walking off a d16z6
Old May 27, 2010 | 05:48 PM
Elitesky's Avatar
Default timing belt walking off a d16z6
i just put a swap in my 91 crx si and when i start it up the timing belt starts to walk off i changed the tensioner and still same thing.. currently working on it so please help asap
thanks
Old May 27, 2010 | 08:17 PM
Elitesky's Avatar
Default Re: timing belt walking off a d16z6
okay i looked futher into it and found there are two guide washer i guess thats what they are called on each side of the crank pulley but now after driving the rex it sounds like a 2 step at 3500 and when i shift its sluggish.. any suggestions on that problem? i thought maybe it was the chip in the p28 ecu but i pulled out and same problem.. going to bed any help is appriciated thank you
sky
Old May 28, 2010 | 02:28 PM
Icon_Ed6's Avatar
Sounds like ur timing is off
Old May 28, 2010 | 03:29 PM
bradennicely's Avatar
check your timing
Old May 28, 2010 | 04:28 PM
~sp33~'s Avatar
EFB055
sky
Yeah those guides must be on there, they'll make the belt track properly. Line your engine back up to TDC, you're off a couple of teeth.
Old May 28, 2010 | 06:01 PM
Elitesky's Avatar
still nothing... its up for sale now 1000 takes it clean car
Old May 28, 2010 | 06:32 PM
~sp33~'s Avatar
EFB055
Did you even try looking at whether the car is at TDC?
Old May 29, 2010 | 05:16 AM
Jasonx056's Avatar
good luck
CHU-JDM-DC2
22
Jan 27, 2016 10:21 AM
pinks11
Feb 22, 2009 05:58 PM
ampm
Mar 12, 2007 11:11 AM
Hatch-E
Oct 2, 2003 06:16 PM
tub_sephiroth
Feb 6, 2003 08:38 PM
