Separate Wire for Tach to work
Old May 27, 2010 | 11:14 AM
Dekorum's Avatar
Default Separate Wire for Tach to work
Does anybody know why you have to run a separate wire to make the tachometer work on certain swaps? I am sure it has to do with the combination of body harness + engine harness, but I want to know for sure. I would like to know why I had to run a wire to my distributor plug from one of the connectors on the driverside shock tower for my tach to work after my swap
Old May 27, 2010 | 11:22 AM
EJeff8's Avatar
Default Re: Separate Wire for Tach to work
Well, you need a wire for the needle to sweep, a wire for the information, and a ground of course.
Old May 27, 2010 | 11:25 AM
Dekorum's Avatar
Yeah, its just one extra wire you have to run on certain swaps. I am just wondering why ..
Old May 27, 2010 | 11:27 AM
EJeff8's Avatar
Could be a pin change.
Old May 27, 2010 | 11:32 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Perhaps the lead on the ignitor inside the distributor that's off to the side (this is the tach signal) is loose or off?
Old May 27, 2010 | 11:53 AM
CivicSpoon's Avatar
'99-'00 Civics (excluding the Si and HX) have Engine Speed Output (signal for the tach) run off of the ECU, rather than the distributor. Where they have the 8-wire plug rather than a 9-wire plug. Does any of that pertain to the swap you're doing?
Maybe you should be a little more specific about what car you have, what harnesses & ECU you're using, and what engine you're putting in.
Old May 27, 2010 | 11:59 AM
B18C5-EH2's Avatar
Former Moderator
Loved
He has a 1992 Civic Si HB with JDM B18C (Type R) and what is supposed to be a 1997 USDM Integra GS-R engine harness. Currently he's running a jumper harness and a JDM P73 ECU.
Old May 27, 2010 | 04:59 PM
Dekorum's Avatar
^^ Correct.
Except the engine harness I am using is supposed to be a USDM Type R harness. Not sure of the year though!
Old May 28, 2010 | 02:41 PM
Dekorum's Avatar
Any one else have any ideas?
Old May 28, 2010 | 02:44 PM
Gunmetal_B20_Hatch's Avatar
light blue wire between DS shock tower and firewall?
Old May 28, 2010 | 02:48 PM
Dekorum's Avatar
Right, I believe that is supposed to be it. I am wondering WHY it did not control my tach once I dropped in the OBD2 Type R USDM harness like plug and play. I had to run an extra wire directly from the DS shock tower connector to the distributor connector. My tach works perfectly now. I am just wondering WHY I had to do it, when I have heard of others just using an OBD2a harness in an EG swap and it works the tach plug and play.
Old May 28, 2010 | 02:54 PM
I would go with the above post by B18C5-EH2 about the difference in 8 and 9-pin plugs.
Old May 28, 2010 | 04:01 PM
Dekorum's Avatar
Well CivicSpoon said that about 99-00 Civics. I don't have anything from a 99-00 Civic in my setup..
Old May 28, 2010 | 05:29 PM
CivicSpoon's Avatar
Maybe something in this thread has something to do with it?
https://honda-tech.com/forums/acura-integra-type-r-8/jdm-itr-ecu-tach-signal-different-than-usdm-2118063/
The only other thing I can find from a search is a LOT of people having the same issue. But I haven't seen a single answer as to why. I wish I had a copy of the '98-'01 Integra ETM to check it out myself.
Old May 28, 2010 | 05:42 PM
Dekorum's Avatar
Hmm.. well I was running a P28 at first, and my tach still didn't work. So this may mean that the USDM Type R engine harness I bought from a friend is a 2000-2001 one? I know the engine is a 96 JDM ITR.
Old May 28, 2010 | 05:43 PM
Dekorum's Avatar
Wait, wouldn't there be a noticeable difference in the 97-98 and the 00-01 Type R engine harness? If I knew what they were, I would go out and check if I see any of them on my harness.
Old May 28, 2010 | 07:27 PM
CivicSpoon's Avatar
We didn't get OBD2A ITRs over here in N. America; the Type R's were only sold here in '00-'01 (OBD2B). There would be differences between the models, which could narrow it down. The GS-R would have wiring for the IAB and the LS wouldn't have wiring for VTEC. But as for OBD2A vs OBD2B harness differences, I don't know. Seems this may be one of those "little" things that the Honda community may not have a definite answer for.
Old May 28, 2010 | 07:31 PM
Dekorum's Avatar
Haha, maybe I can't get a definite answer. But I thought I would try.
Also, there definitely WAS an OBD2A ITR in North America. 1997-1998 did exist in America. Japan got the 1996 which we didn't. And the 1999 did not exist anywhere.
Old May 29, 2010 | 05:43 PM
CivicSpoon's Avatar
OMG, how did I not know that... I would have put $ on the fact that the Type R came here in '00. I don't know why I thought that.
Old May 29, 2010 | 07:42 PM
Dekorum's Avatar
Haha, you mean 99. Cause they did come here in '00!
epingquian
Mar 29, 2018 08:29 AM
4dooreg-k
11
Jun 23, 2006 12:50 PM
1sikhatch
11
Mar 14, 2006 09:19 PM
YellowCRXSi
Jul 12, 2004 09:55 PM
serious
Jan 22, 2003 11:21 PM
