NEED HELP GOING CRAZY!!!!!
Old May 26, 2010 | 08:52 PM
da91992's Avatar
Icon3 NEED HELP GOING CRAZY!!!!!
Alright this is the rundown new to the honda world and I own a 92 acura integra which has a jdm b16 obd1 and it ran awesome since owning it until I decided to change both cap and rotor and plugs which just straight screwed me big time now the car on acceleration just going from stop to go starts backfiring like crazy to about 3 thousand rpms then it will clean up run fine till you hit 5 thousand and really starting backfiring like crazy but after driving a lil bit it cleans up and powerband is smooth all the way through its just intermittent so any help would be much appreciated its my dd so gotta get it up and going as quick as possible.
What ive replaced so far to fix problem
1.cap and rotor from dealer
2.ignitor
3.map sensor
4.spark plugs ngk g power
Old May 27, 2010 | 05:58 AM
fcm's Avatar
fcm
Old Fart
Default Re: NEED HELP GOING CRAZY!!!!!
Are spark plug lead sequence correct?
Have you checked timing? 94
Old May 27, 2010 | 11:54 AM
ekb16's Avatar
sounds like you may have put the plug wires in diff. spots
Old May 27, 2010 | 12:53 PM
thapimpfromchi's Avatar
yea. make sure you put the plug wires back on where they belong. also, did you take the distributor OFF to put the cap and rotor on? make sure you put it back exactly like it was. if you didnt you might have affected the timing.
Old May 27, 2010 | 04:22 PM
da91992's Avatar
Yea I checked wires and there in right spot and I didn't remove the distributor just took cap and rotor off and replaced both and I've noticed once car gets warmed up to running temperature it clears up and runs like a champ you think possible o2 sensor throwing off car and there are no engine codes coming on either
Old May 27, 2010 | 08:39 PM
did you replace the big *** like o-ring thing? make sure there is a good seal. i had a car mess up cuz the o-ring thing was dried up and cracking so moisture was getting in there. once i replaced it, i cleaned up the contacts a little, and it was perfect.
Old May 28, 2010 | 08:46 AM
da91992's Avatar
Yea when I purchased the disributor from dealer it came with a new one but the o ring seemed to thin and didn't seem to seat snug
Old May 28, 2010 | 09:07 AM
nemisish20's Avatar
Wheres my titleeeee!
You can check two things. Is the CEL light on? And My B16 used to do the same thing once in a while. The TPS sensor went bad causing it to bog up until about 2500-3k. After that it cleared up and i went nuts for about a week trying to figure it out.
If the cel is on check to see if you have a code 4. My buddy's CRX is doing the same thing because of the crank position sensor in the distributor.
Old May 28, 2010 | 11:48 AM
da91992's Avatar
There's no CEL lights on but imma check the tps imma switch it out and see what happens
Old May 28, 2010 | 12:13 PM
da91992's Avatar
Scratch that apparently tps is riveted on any way I can pull out rivets and re rivet it
Old May 28, 2010 | 12:23 PM
lol. those arent rivets. just some ****ed up *** screws. I HAAAATE messing with TPS's cuz of those things. There is no good/easy way of getting those off that I know if.
Old May 28, 2010 | 02:27 PM
mouab18c1's Avatar
Hack saw blade, slowly saw the screws so that it will fit a screwdriver. Once those ugly ones are out replace them with normal screws. Simple and easy
mynameizstitch
Jun 8, 2009 07:29 AM
austinkli
23
Feb 7, 2008 12:57 PM
k_spec
May 31, 2005 10:31 PM
slow99si
12
Feb 4, 2005 06:59 PM
ELHatchyBlanco
Mar 16, 2004 09:57 AM
