P0108
Old May 26, 2010 | 12:37 PM
96civic turbo's Avatar
Icon2 P0108
I have a 1996 Honda Civic Ex (D16Y8) with a Greddy turbo kit installed. I have not owned the car for long and I am new to tuner cars. The car throws a CEL code of P0108 whenever I get on it and the turbo spools up. I have installed a new Map sensor and it still does it. Anyone know a fix?
Thanks
Old May 26, 2010 | 02:00 PM
Relic1's Avatar
Default Re: P0108
P0108 Manifold Absolute Pressure (MAP) Sensor Circuit High Voltage
( https://honda-tech.com/forums/tech-misc-15/heres-list-obd2-codes-if-anyone-cares-466877/ )
based on the fact that you can scan for codes with a scanner, you have an OBD2 ECU. Since honda never produced an OBD2 civic ECU with boost, that's why you're setting the CEL.
the only way to do this right is to buy an OBD2a-OBD1 conversion harness, and an OBD1 ECU that's chipped for your setup... then have it tuned.
Old May 26, 2010 | 02:10 PM
JDM_7's Avatar
Default Re: P0108
( https://honda-tech.com/forums/showthread.php?t=466877 )
+1
Default Re: P0108
Where can I buy the conversion harness and ODB1 ecu that is chipped for my setup?
Old May 26, 2010 | 02:46 PM
Relic1's Avatar
Default Re: P0108
http://www.phearable.net
http://www.xenocron.com
Old May 26, 2010 | 05:30 PM
Default Re: P0108
Thanks for the links. I wonder why they did not change the ecu when they installed a turbo?
Old May 26, 2010 | 06:23 PM
Relic1's Avatar
Default Re: P0108
they likely did but switched it back when they sold it.
or that's the only way to get it to pass emissions to be able to be sold.
or they had no idea what they were doing and couldn't get the CEL to stop so they sold it...
the latter would worry me more, more problems may be undiscovered.
Old May 27, 2010 | 02:53 AM
Default Re: P0108
Once I get a chipped ecu tuned for my car, will it run right without getting a dyno tune?
Old May 27, 2010 | 03:54 AM
grumblemarc's Avatar
The Grumpiest
Default Re: P0108
Probably not the way you think.
Old May 27, 2010 | 07:04 AM
Relic1's Avatar
Default Re: P0108
that's about the best way to put it.
the ECU is chipped with a basemap, it's the basic maps you need to get the car running.
Tuning is the process of reading what the engine is doing with those maps and adjusting so the engine runs correctly. This requires (at minimal) a wideband and some street tuning time. But if at all possible, some dyno time, which will help in every way.
Old Aug 9, 2010 | 03:23 AM
Default Re: P0108
I installed a Walbro fuel pump, RC 440cc fuel injectors and a Chipped Obd1 Vtec Ecu from Phearable.net and the car runs fine. Turbo spools up and pulls like a raped ape with no engine lights. Time for a dyno tune.
92eg_MOB
Mar 8, 2009 08:05 PM
Mikes2000civicsi
Oct 2, 2007 05:45 PM
otakueric
Sep 13, 2005 04:49 PM
VinceVTEC
13
Nov 22, 2004 05:43 PM
NuRv
Oct 24, 2004 02:47 PM
