Suspension & Brakes Theory, alignment, spring rates....
Suspension Problem
Old May 26, 2010 | 12:15 PM
2.2accord's Avatar
Default Suspension Problem
Hi, i have a 95 honda accord lowered on coilover sleeves, i got pulled over by the cops today and he stated my car was to bouncy in the rear, i was wondering if i replace the shocks if that would stop the car from bouncing as much as it does now?
Old May 26, 2010 | 12:44 PM
JAYDmManny1331's Avatar
Default Re: Suspension Problem
depends have you checked your struts to see if there blown might just be the coilovers
Old May 26, 2010 | 12:55 PM
98civdx's Avatar
Master Detailer
If they are ebay they will bounch like hell, however good shocks will help a lot.
Old May 26, 2010 | 01:58 PM
2.2accord's Avatar
Well, when the back end is up in the air I can push the whole wheel assembly up....like the shock has no pressure
The cop says if I don't have it fixed in a week, he will tow my car away. So I need to get fixed asap.
Are gabriel shocks any good? I need to fix it quick and kind of cheap don't have a lot of cash
Any ideas? Thanks
Old May 26, 2010 | 02:53 PM
robotosan's Avatar
what coilovers and what shocks are you using for starters?
Old May 26, 2010 | 03:33 PM
2.2accord's Avatar
I got the sleeves as a gift....and its on stock shocks....I actually priced monroe shocks they are $56 a piece with lifetime warranty.
All I know the sleeves are black and the spring is blue
Old May 26, 2010 | 04:00 PM
robotosan's Avatar
the monroe shocks are going to be oem replacements... they're not going to do anything. Just bite the bullet and get tokico illuminas; if you wana play you gotta pay.
Old May 26, 2010 | 04:17 PM
2.2accord's Avatar
I honestly don't care if its bouncy, I just want it less bouncy so the pig can
Shut up....
Old May 26, 2010 | 04:23 PM
TunerN00b's Avatar
Shut up....
Bouncy is underdamped. You need more shock damping (or less spring rate) to stop the bounce.
Bilstein Sport/HD, KYB AGX, Tokico Illumina, etc...
Old May 26, 2010 | 04:32 PM
robotosan's Avatar
Shut up....
then buy the illumina shocks... im sorry to be frank, but are you completely mental?
Old May 27, 2010 | 09:56 PM
361 accord's Avatar
foo u cant have super stiff stings and loose shocks it will bounce, monroe=oem=loose
you can however have stiff shocks and loose oem springs
you can have adjustable shocks that would be the best bet!
Old May 27, 2010 | 09:58 PM
361 accord's Avatar
lmfao he said the *** bounces in the rear
throw some bricks in it, OR
my option wouild but to just bottom out the sleeve as low as it goes, like literally ride around bottomed the f out!
josejdm
Suspension & Brakes
Feb 24, 2010 06:30 PM
BoboyRS
Feb 9, 2009 05:54 AM
dblock
16
Mar 21, 2007 05:37 AM
-iLLuZioN-B18C1
Apr 22, 2003 08:52 PM
mmasse
Jul 23, 2002 07:38 PM
