It's crunch time and I need some advise!
I am at a crossroads. I have narrowed my choices to two turbine housings. Either a T3
divided 84 A/R housing or a T4 non-divided 81 A/R housing. I have an inlinepro t4 manifold,
3" full exhaust, stock bore ls/vtec with gsr cams and an AEBS intake manifold. Thanks H-T!
Its a garrett t3/t4/t67. I will be drag racing with some street use but minimal. I want ot
make all I can on pump and over 500 on race gas. I was hoping that you would help me out
with this shodan! You seem to always have good advise and it's much appreciated!
That style inlinepro manifold is dual drilled for both t3 and t4. Also I will be upgrading to a 84mm sleeved bottom end over the winter.
Agreed.
Also, an undivided 0.81 T4 is WAY bigger than a divided 0.84 T3.
I don't seem why your choice is between these two as they're very different.
A T67 is on the big side for someone only looking for 500whp on race. A 60-62mm turbo is probably a better choice as you're accepting a lot of unnecessary lag with a T67.
If you are really set on getting the T67 and have a T4 manifold, get an 0.68 T4. If it's a P-trim turbine you might even get away with an 0.58 T4, but it's a mismatch and might be prone to surge.
IMO you want a T61 or something though, really.
I already have the turbo, I'm just looking at changing housings. I suppose I could trade it for
a smaller 62mm but I am hoping when I get my sleeved block finished to shoot for more
power still. Just shooting some ideas out there I guess. Thanks for all the input so far and
please keep it coming!
h22turbolude
Dec 10, 2003 09:30 AM
