poor performing b20 vtec
Old May 26, 2010 | 05:42 AM
LSvtecRSA's Avatar
Default poor performing b20 vtec
hi all
i've built a b20 with the following:
b20b block
b16ahead
wiseco 10.9:1 pistons
eagle h-beams
oem b20 crank
crower 63401's
toyota 43mm itbs with ram stacks
adj cam gears
a decent header
2 1/2" exh
now the problem is that it only made 113hp, camtiming was perfect and compression was good... could it be that one of the cylinders' vtec lobe is not engaging? i can hear the vtec engage but not as loud as when it used to be a b18...
Old May 26, 2010 | 09:40 AM
DDTECH's Avatar
Default Re: poor performing b20 vtec
....sounds like something is seriously wrong.
Old May 26, 2010 | 09:48 AM
1.5Slowmatic's Avatar
ummm damn. LEak down and compression tests done?
Old Jun 1, 2010 | 09:03 AM
LSvtecRSA's Avatar
turned out to be compression
now that everything has been assembled i noticed that my rockers has been milled where the cam actually touches the rocker, will this affect the rocker piston movement, because vtec activation is hardy noticeabe...
Old Jun 1, 2010 | 09:43 AM
Mr_ET's Avatar
I have a similar issue and also reused older rockers but they weren't touched aside from a good cleanup.
My VTEC also engages and makes no power. Compression is good across the board.
Let me know if swapping rockers fixes it?
Old Jun 1, 2010 | 10:40 AM
kyden's Avatar
there should be enough adjustment in the rocker arm.
Old Jun 1, 2010 | 12:38 PM
LSvtecRSA's Avatar
i'm connecting the aircompressor to the head and turning it over by hand tomorrow, if all the rockers go into second stage i'll be very happy
Old Jun 4, 2010 | 06:34 AM
LSvtecRSA's Avatar
i replaced the milled rocker arms with stock ones and vtec kicks in very hard, milling rockers should be considered a felony punishable by death...
Old Jun 4, 2010 | 08:21 AM
Mr_ET's Avatar
Were the stock ones brand new or used and did they have any wear on them if they were used?
Old Jun 4, 2010 | 08:53 AM
Maluko's Avatar
Old Jun 5, 2010 | 11:28 AM
LSvtecRSA's Avatar
no they came out of a head that i popped a couple of years back, they have some wear on them but nothing too serious
my valve clearance is a bit on the tight side, but let's see what happens
Old Jun 5, 2010 | 04:59 PM
xzodiackillerx's Avatar
who milled them?
JDM97EK
Oct 28, 2006 09:12 PM
projectTeG
Feb 8, 2004 01:05 PM
b20vtec ef8
Feb 6, 2004 06:17 AM
LSturboHB
Jun 7, 2002 01:47 AM
