Turbo spitting oil
hi i need help i have a problem.... my car boost fine no shaft play holds boost and everything its just after i slam it hard there is oil around the inside of the turbo and on the lip idk how this can happen or y its happening any help?
Well first u should really have a filter on ur turbo. Check all ur feeds and make sure they all are on there tight. Second the oil around ur turbo my first turbo from eBay did that mean ur turbo leaking and is going bad so I would go get it rebuilt stop smashing on it before it blows lol but yeah if it's a good turbo get it rebuilt why u always buy new because they have warrentys on the turbos.
thanks but idk wats up with it the turbo seemd to be good it only happens when i hit boost under normal driving its fine and its an ebay turbo but its completely fine like i said no shaft play spins freely im ??????
I totally disagree it makes no sense to have it rebuilt before figuring out the problem and if it has no shaft play whatsoever it may not need a rebuild.Check the return line to make sure it isnt having issues returning the oil to the pan and what is the oil pressure you are getting on the feed line?
Someone knowledgeable has free reign to correct me but your turbo might not have shaft play and still have blown seals which would lead to the oil buildup on your comp housing(Im assuming from your less than descriptive OP).
Throw the ebay turbo in the trash and get something thats worth running.
On a side note: SiBlues, why dont you like Jdogg?
