Would this be fine to tow?
So i posted a thread about the car i bought for 100 bucks the motor and trans were removed,and i was wondering if it would be okay to tow it without the engine and trans seeing that it probably doesn't way much and i dont want to break anything.I will be towing it 20-30 miles tommorow so please any help would be appreciated.[IMG]
[/IMG]
This is how the car will be towed.
[/IMG]
if you are towing with front wheels on a car dolly you would be fine. if towing with 4 wheels on the ground ild be cautious about the axles spinning and burning through that strap. i have axle ends that i use if i have to tow on the ground to keep the wheel hub and bearings together
wheel bearings, are the biggest issue you would have, move the axel straps to the rear cross member and make sure your axels nuts are on and you should be fine, but make sure the brakes work before you hit the road
beanbag
Dec 7, 2008 09:30 PM
hybrid1990crx
Dec 20, 2006 10:10 PM
