crx lights
Old May 24, 2010 | 10:52 PM
ft541's Avatar
Default crx lights
Ok so im wondering how do u make ur trun signals blink hella fast? Iv seen it done b4 i know that they blink fast when u have a bulb out but theres another way to set them so they will blink hella fast if some one could let me know i think its pretty coo
Old May 24, 2010 | 10:53 PM
StayKrafty's Avatar
Default Re: crx lights
I would assume that is a bad idea, since to other drivers they see that as a hazard for them.
Old May 24, 2010 | 11:00 PM
ft541's Avatar
HAZARD???? wtf that would actually be better what bout if u gonna change lanes quick normal blinker is slow but if u had these it would be better for the drivers behind u
Old May 24, 2010 | 11:03 PM
StayKrafty's Avatar
Yeah, maybe you're right, I'm over thinking this one.
Old May 24, 2010 | 11:07 PM
ft541's Avatar
ya i know some body here has to know how to do this
Old May 25, 2010 | 02:02 AM
BrayzieEF9's Avatar
FAIL!!!
Old May 25, 2010 | 05:34 AM
Aftermath_Hatch's Avatar
If you put LED blubs in it it would do that,but not really thinkin it's a good idea.
Old May 25, 2010 | 05:42 AM
Jockone's Avatar
Most states that require a saftey inspection will have a speed that the flashers can flash at/so many times a minute,I would check on that before I changed the speed as it might cause you to get pulled over.
Old May 25, 2010 | 05:48 AM
crx_si-r's Avatar
i will be the first to admit, i did have this on my old 89 HB. would i do it again, F&*% NO!
it will get you pulled over (its one of the things cops look for, because they can pull you over for a fix it ticket and just go from there), however if you still want to do this. all you need is to go on ebay and look up "hyper blinker."
what this is, is its a modified flasher for your car that you just swap out with the stock one from your cars fuse box, causing your lights to blink extremely fast.
Old May 25, 2010 | 08:00 AM
Ass$nyper's Avatar
Pirate General...YARRRR
This thread is worse then listening to Juice Newton on repeat on a 9 hour drive in the snow up hill to go put your dog down.
myed9crx
Southeast (Sales)
Jan 19, 2011 04:23 AM
JuneBugDrfter
May 12, 2010 09:51 AM
carlthecrx
Lighting
10
Nov 14, 2007 01:40 AM
crx_88_si
Mar 22, 2004 01:47 PM
MNCRXSi
Jun 4, 2002 02:33 PM
