Lighting HID/Xenon kits, Retrofits and Associated Topics
city lights on crx?
Old Oct 24, 2007 | 02:36 PM
carlthecrx's Avatar
Default city lights on crx?
was thinking of putting city lights on my crx this weekend.. a quick little project just for fun... but i've never seen it on a crx before, or at least i haven't noticed.. has anyone else done this, or seen it done?
Old Oct 28, 2007 | 08:21 PM
k0rupt_ed's Avatar
what size bulbs are in the crx?
Old Oct 30, 2007 | 09:41 AM
carlthecrx's Avatar
Default Re: (k0rupt_ed)
i have no clue... why do you ask? my understanding of a city light was just drilling a hole and adding an amber bulb to the headlight housing, but i could be wrong
Old Nov 9, 2007 | 08:50 PM
badboyr66's Avatar
Default Re: (carlthecrx)
Would be easy to do. I would look into larger LEDs for it. I would also use a rubber dough nut from the hardware store to hold it in place of the corresponding hole you will have to drill
brought this back to see if anyone else had insight as I am doing the same
Old Nov 10, 2007 | 06:52 AM
k0rupt_ed's Avatar
if its a h4 i believe ebay has a kit that just sleeves onto the bulb
Old Nov 12, 2007 | 12:38 PM
inh's Avatar
inh
I wouldnt want to put anything that sleeves over a bulb.. Just doesnt seem like a good idea..
I'd drill small hole and put like a 5 watt LED in there.. Maybe even one that isnt so bright..
Old Nov 13, 2007 | 05:23 AM
M30B35's Avatar
Default Re: (inh)
You trying to do something like this? just use a 5w wedge bulb. but youd have to figure out a way to mount it, the e34 has a long tube w/ a socket that the bulb plugs into. the tube then plugs into the headlight
Old Nov 13, 2007 | 07:01 AM
k0rupt_ed's Avatar
city light illuminates the whole bulb.
With led's the issue is heat, those 5 watt's burn up quick
Old Nov 13, 2007 | 07:44 AM
M30B35's Avatar
depends on how the light is made, bimmers have a partition in them so that it doesnt illuminate the entire light. W5 filiment bulb should not burn up too quick at all and an LED will be even cooler
Old Nov 13, 2007 | 11:49 AM
badboyr66's Avatar
Default Re: (inh)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by inh &raquo;</TD></TR><TR><TD CLASS="quote">I wouldnt want to put anything that sleeves over a bulb.. Just doesnt seem like a good idea..
I'd drill small hole and put like a 5 watt LED in there.. Maybe even one that isnt so bright..</TD></TR></TABLE>
It is not an actual sleeve. It is a protruding piece that sticks out below the bulb. Actually a nice piece but it does not allow for a 194 bulb... so you could not put an LED in there.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k0rupt_ed &raquo;</TD></TR><TR><TD CLASS="quote">city light illuminates the whole bulb.
With led's the issue is heat, those 5 watt's burn up quick</TD></TR></TABLE>
What heat issue do you speak of? I had city lights built into the housings on my GTI and I had LEDs in there with no trouble. Plus there is no filament to burn out
Only problem I had was LEDs are pretty directional and you could not see it well at all angles. So I was hoping someone knew of a LED that spread the light more
Old Nov 14, 2007 | 01:40 AM
inh's Avatar
inh
The heat issue was in reference to my 5 watt LED idea. They are some of the newest LED's out and are also the brightest. They can also get quite hot..
I see what yuo mean about the sleeve now, kinda cool. Might be worth making something similar for an H4 bulb..
Also, about the LEDs, angle it back towards the reflector and it should work great. If you point the LED out towards the front of the car it wont work well at all, as little, if any light will be bounce around the reflector.
Vagitarian
12
May 20, 2013 04:36 PM
MATiC
Jan 23, 2007 05:12 PM
hondaboy4life
Jun 19, 2005 12:46 PM
xmattoxx
Oct 27, 2002 02:14 PM
MNCRXSi
Jun 4, 2002 02:33 PM
