Radiator...tube busted...please help
Old Sep 12, 2002 | 03:30 PM
reekoh's Avatar
Default Radiator...tube busted...please help
Hey everybody. Today while I was drving, the tube that connects from the radiator to the engine popped...there's a hole. It's the tube that transfers the coolant to the engine. It happened while I was drving and then my engine overheated. Does anybody know how much to replace that tube and where I can get a replacement? I hope you guys know what I'm talking about. Thanks. Also, is there anything I should be worried about? I only drove another five minutes after it happened?
Old Sep 12, 2002 | 04:18 PM
MR. ARIZONA's Avatar
Default Re: Radiator...tube busted...please help (reekoh)
Just run down to the AUTOZONE, or even your HONDA DEALER and get a NEW HOSE. They don't cost much at all. Your fine. Just install the new hose and replace the ANITFREEZE. Good luck
Old Sep 12, 2002 | 04:49 PM
Tweakmeister's Avatar
yep....but use Honda brand Antifreeze (mixed correctly).
you might have cracked the radiator if you overheated (the top plastic is a known weakpoint)....but one thing at a time!
Old Sep 12, 2002 | 06:57 PM
frogsr's Avatar
Default Re: Radiator...tube busted...please help (Tweakmeister)
i believe that would be the type 2 coolant--premixed already. just add into the radiator and you're good to go.
condor22
Jan 23, 2019 05:12 PM
WHAT TEH
Nov 12, 2006 07:43 AM
grom
Aug 30, 2006 08:21 AM
ururk
14
Aug 26, 2005 05:27 PM
sniperslayer
Jun 30, 2005 11:14 AM
