Blower Motor Question
Old May 24, 2010 | 06:42 PM
s13hero's Avatar
Default Blower Motor Question
I removed the blower assembly as well as my evaporator to install new a/c thermostat, and when I reinstalled it all, the blower still works, but I'm barely getting any air through the vents, what did I do or forget to hook up? I looked at it seems fine other than the air.
Old May 24, 2010 | 06:48 PM
Former User's Avatar
Default Re: Blower Motor Question
Is the mode control motor working?
Old May 24, 2010 | 07:13 PM
EHondaD6's Avatar
Make sure the blower is sealed correctly and you didnt remove any ducts..it will cause the air to escape somewhere else besides through your vents..
Old May 24, 2010 | 07:14 PM
s13hero's Avatar
Is that what opens or closes the door when I change the a/c mode?
Old May 25, 2010 | 02:14 PM
s13hero's Avatar
BUMP
Old May 26, 2010 | 11:28 PM
s13hero's Avatar
BUMP mode motor is working, it opens and closes the door when I change modes,just not enough air is getting out can't feel it on 1-3, only a bit on 4.
Old May 28, 2010 | 01:38 AM
s13hero's Avatar
BUMP
Old May 28, 2010 | 03:40 AM
richi86's Avatar
there could be bad seals on the vent ducts or around the blower motor its self
Old May 29, 2010 | 04:57 PM
s13hero's Avatar
Do you know if its possible to get new seals? I didn't see any except for the side facing the top of the dash.
Old May 29, 2010 | 05:36 PM
richi86's Avatar
well i know when we ripped out my buddy's vents and all that in his civic when we did a harness swap and we had to get that foam tape stuff that goes around the vents from there it was only a couple dollars for a whole roll of it. i cant remember on the civics blower motors there should be a black hose on there that goes into the blower motors casing n then into the blower motor housing if there is check that
if its a different kind of seal u need the u will have to call a Honda dealer
below is the foam type
seal i am talking about
Old May 31, 2010 | 06:50 PM
s13hero's Avatar
Yeah thats it, guess I'll go look for a roll of it. The only hose I know of the drainage one, and it connects to the evaporator, and not the blower.
unclematt
Nov 14, 2017 01:09 PM
lphthephunk
Aug 9, 2014 05:49 AM
Mr. Fancypants
Jan 18, 2011 11:22 AM
kyleclapp
Jan 16, 2008 01:44 AM
VTEC-LUDE
Jul 22, 2007 05:01 PM
