speedo reading off
Old May 24, 2010 | 06:03 PM
hardcore97's Avatar
Default speedo reading off
well i just swapped odometers out since my SI cluster had a peice broken on the odometer which was making it not work. i swapped the speedo assembly from a 97 dx cluster onto it, swapped the board over from the SI cluster as well as the peice with the pin the needle goes onto. its reading about 5mph off and driving me crazy. it was right on before i swapped the parts out. got any ideas as to what it could be?
Old May 25, 2010 | 12:47 PM
hardcore97's Avatar
Default Re: speedo reading off
any ideas? someone told me it was because its from a dx but Dx and EX wheels and tires are the same exact size so thats the issue. it worked perfectly before i swapped it out so idk. i guess il have to deal with it if i want a working odometer
Old May 26, 2010 | 12:42 PM
ca-rs's Avatar
Speedo must be from a car with 13" tires. Maybe it was swapped before you got it from the DX?
Old May 26, 2010 | 05:53 PM
SoFlaNut's Avatar
My 97 delsol has always 5 out from new. I have a 2009 Hyundai its speedo is 5 off. My guess it has something to do with the smaller wheels. Look on the bright side if you think you are speeding you will always be 5 under what you think.
Old May 26, 2010 | 06:14 PM
saltybeagle's Avatar
I know that those speedometer needles are pretty sensitive. If you take them off something doesn't always go back together right and its never the same after. Might just me the cluster. Don't worry about it too much. Could be the tire thing. Most Hondas then came stock with 13s.
Old May 27, 2010 | 12:02 AM
chewyv's Avatar
pm4nudes
might as well just go crazy
Old May 27, 2010 | 12:28 PM
hardcore97's Avatar
dx and ex both came with the same size tire in 97. both 185 65 14 so its not a difference in tire size throwing it off.
fred200
Honda Civic (2006 - 2015)
Aug 11, 2015 07:08 AM
pos_cd5
May 15, 2007 10:56 AM
b16ek
25
Nov 22, 2005 09:30 PM
StreetRacinVejita
Oct 10, 2004 04:47 PM
BumpinVTEC
May 21, 2004 11:23 PM
