96 civic lx with idling problem
Old May 24, 2010 | 06:42 AM
skippysg's Avatar
Default 96 civic lx with idling problem
stock civic w/5 speed, 150k
Items recently replaced: alternator, battery
Problem: After the car has been running 5+ minutes, it will no longer idle when you come to a stop. It will idle but just barely and I'm having to give it gas to keep it going. Once I get going though it runs fine with no signs of any problems. Any ideas?
Old May 24, 2010 | 05:12 PM
tonyhatchetman's Avatar
Default Re: 96 civic lx with idling problem
clean the iacv.
Old May 24, 2010 | 07:11 PM
JAYDmManny1331's Avatar
what he said
Old May 24, 2010 | 07:23 PM
D16SiHatch's Avatar
so the idle doesn't fluctuate at all? have you tried raising the idle a bit via the screw in the tb
Old May 25, 2010 | 08:52 PM
skippysg's Avatar
When it is warm, it stays about the same rpm and idling very rough or dying, not fluctuating. Tonight it died once on the way home but it starts right back up, popped the clutch as I was on a hill and it fired up.
I have listened for any vacuum leaks and nothing seems to be hissing, etc. I have never touched the screw in the tb.
Old May 26, 2010 | 07:13 PM
Originally Posted by tonyhatchetman
clean the iacv.
and bleed the coolant system
Old May 26, 2010 | 08:46 PM
vansxskater's Avatar
Wouldnt air bubbles in the coolant cause the car to have a surging idle, not making the car bog out and die?
Old May 26, 2010 | 09:03 PM
metrolsi's Avatar
clean the iacv.
i did it to mine and worked like a charm....
Old May 27, 2010 | 06:45 PM
skippysg's Avatar
I sprayed some carb cleaner in there for now until I have time to tear it apart and clean it. It has made a difference already. Thanks for the help everyone.
Old May 27, 2010 | 06:52 PM
96DelSol's Avatar
Clean the iacv and might as well flush the coolant in radiator.
crxguy406
Sep 10, 2015 03:56 AM
dices543
13
Nov 19, 2010 04:07 AM
dth0ng69
25
May 18, 2009 08:30 AM
LST2
Jun 24, 2008 11:53 AM
ic89
Oct 16, 2006 05:38 PM
