im being a cheap ass. vtec questions
Old May 23, 2010 | 06:55 PM
mayfly's Avatar
Default im being a cheap ***. vtec questions
ok so im going to do a mini me on my d15b7 bottom. i dont wanna spend the extra money for a p28 and convert to obd1.
so im planning on using my apexi vtec controller to run vtec, and use the pm6. now for the distributor im going to make a harness so i can use the plugs from my harness and clip right into the dizzy.
now this is all until i have enough to get the p28 and make a 0bd1 harness.
anyone? thoughts? i feel like this should work.will my motor be in limp mode?
Old May 23, 2010 | 07:17 PM
D16SiHatch's Avatar
Default Re: im being a cheap ***. vtec questions
if you are using an obd1 dizzy, which it sounds like that's your plan, then yes.
now if you use the obd0 si dizzy it will work perfectly fine
Old May 23, 2010 | 07:18 PM
424racer's Avatar
you need to use your obd0 si dizzy untill you convert everything to obd1.
you cant use a obd1 dizzy on obd0.
you will need to cut the leg on the obd0 dizzy so the time will line up.
the top leg only and it will be the only leg that you would be able to bolt on....
Old May 23, 2010 | 07:24 PM
D16SiHatch's Avatar
if he is using a z6 yes. if it's a y8, the a6 dizzy will bolt up to all 3 mounting points
Old May 23, 2010 | 09:15 PM
uncl3j0n's Avatar
Just get a p05 or p06 and pay the 100 bills to get it vtec converted
Old May 23, 2010 | 09:23 PM
D16SiHatch's Avatar
why would you do that when you can get a p28 for $100 or less?
Old May 23, 2010 | 10:25 PM
mayfly's Avatar
ok so lets back up real quick.
whats the problem with running the a6 dizzy?
whats the problem with running the z6 dizzy?
Old May 23, 2010 | 10:30 PM
speedooo's Avatar
bolt pattern for the distributor on p08 cast heads is different from every other sohc head...
Old May 23, 2010 | 10:37 PM
mayfly's Avatar
ok fa sho. ill just run the z6 dizzy and make the plug harness. then everything should just hook up and i can run vtec off the vafc. correct?
Old May 24, 2010 | 01:36 AM
HondaPartsHero's Avatar
Technical Hero
you can't use the Z6 dizzy with the OBD0 ECU, it won't run
Old May 24, 2010 | 09:58 AM
speedooo's Avatar
I've never tried it but the internals from each distributor could probably be swapped...
Old May 24, 2010 | 11:05 AM
Technical Hero
no can't be swapped
1990crx420
Jun 7, 2009 04:20 PM
lilsicsoul
13
Jan 26, 2009 07:20 PM
yoffer
18
Dec 17, 2007 05:13 AM
bluelsvtecda9
Apr 10, 2007 09:55 AM
gvillehnut
Mar 10, 2003 10:24 AM
