del sol brake lights are stuck on...
Old May 23, 2010 | 06:34 PM
si90rex's Avatar
Default del sol brake lights are stuck on...
my uncles del sol brake lights are stuck on. Since the brake switch is 50 bucks is there a quick way to test this. i'll have some time to pull the fuse box and check the switch in a few days. any help would be great.
i believe its a 1994 del sol d16z6
Old May 23, 2010 | 06:42 PM
Linked's Avatar
Default Re: del sol brake lights are stuck on...
the brake switch attached to the brake pedal is just a simple switch
you can disconnect it and put a jumper wire in the connector to see if it comes on or off, idk which does which
but that'll determine a faulty switch
Old May 23, 2010 | 06:54 PM
xero_xero's Avatar
The switch is a button, that when properly adjusted will brake the connection for the lights to be on when the pedal is NOT depressed. you will be able to see the button just above the rubber foot mount, it is not attached to the brae pedal, it is closer to the driver and you can adjust it with 2 10mm wrenches.
Old May 23, 2010 | 08:07 PM
delsolguy32's Avatar
this happened to mine. under the brake pedal there is like a little grommit thing that broke off (for me at least) check to see if its broken. and if it is then just take a small bolt and put on it or atleast thats what i did. it helped out.
Old May 23, 2010 | 08:51 PM
D16SiHatch's Avatar
http://www.jdmuniverse.com/forums/ho...hts-stuck.html
Old May 24, 2010 | 03:51 PM
si90rex's Avatar
thank you, so much i'll look into the missing tab i thought i saw plastic on the carpet... a 2dallor fix would be sweet! i'll keep you posted
Old May 24, 2010 | 05:01 PM
apexi_rsx's Avatar
brake light can be stuck on also when your low on brake fluid. check that first. if your talking about the dash light? if not maybe your pedal needs adjusted?
Old May 24, 2010 | 07:30 PM
si90rex's Avatar
i looked at a few hours ago the plastic piece is broke....the link helped
thanks
Old May 24, 2010 | 07:31 PM
D16SiHatch's Avatar
not a prob. glad you got it fixed
Old May 24, 2010 | 07:41 PM
Black Diamond's Avatar
Yeah that thing is a son of a bitch to get back in too!! Mine had gotten stuck on and it was just simply really Dusty!! But i took it out an cleaned it up..Easy fix, Good luck OP
Bimmerman
Feb 10, 2018 07:46 PM
Ohmster
Aug 19, 2009 11:39 AM
Morgana Invictus
Sep 21, 2008 10:28 AM
Civic Racer X 7
Jun 10, 2006 09:59 PM
solbats
14
Sep 6, 2004 03:18 PM
