D16z6 ? d16y8
Old May 23, 2010 | 04:14 PM
TheCivicMafia's Avatar
Default D16z6 ? d16y8
Ive got a y8 with a spun bearing crank probbly isnt any good, bearing is really thrashed or whats left of it.
ive got a z6 block with a good crank, Whats the difference in cranks? the stoke is the same, journal size is the same, but are they interchangeable?
Any body with facts would be helpful.
Old May 23, 2010 | 04:21 PM
Rauch's Avatar
Default Re: D16z6 ? d16y8
Definitely.
I'd stick with the Z6 crank over the Y8 crank any day. They're almost identical. The Z6 has a second oil channel which the Y8 lacks.
Old May 23, 2010 | 06:39 PM
Thanks man. i thought they were the same, ive just never really messed with a d series crankshaft before.
Do i need to swap oil pumps or what when i switch to the z6
Old May 23, 2010 | 08:31 PM
Rauch's Avatar
I'm pretty sure both pumps are identical. The only thing that can be seen is the y8 pump has a slightly lower output, but I'm almost positive it's due to just having one oil channel and put on the dual-channel z6 crank it'll produce the same output as the z6 pump
AbitAvenger
Feb 22, 2012 12:35 PM
HiProfile
Oct 10, 2006 06:19 PM
d16dcoe45
Oct 4, 2006 01:03 PM
O16581724 5 2 5
May 20, 2005 09:50 AM
