WTK B16a axles/driveshafts
Old May 23, 2010 | 02:10 PM
SiR1097's Avatar
Icon6 WTK B16a axles/driveshafts
Just looking for some clarification here.
I have a 99-00 SiR Civic (JDM) with a b16a4 engine, manual transmission. My passenger side inner axle cup got damaged so I was looking for one to replace it.
My question is, are inner cups from the previous models interchangeable? Meaning would the cup from a 96-98 b16a manual tranny work on my 99-00?
If not, what about the entire axle assembly? And are the left and right cups the same or are they different?
Any help would be appreciated. Thanks.
Old May 23, 2010 | 03:44 PM
98civdx's Avatar
Master Detailer
Default Re: WTK B16a axles/driveshafts
All 32mm B Series axles will work.
Old May 23, 2010 | 03:54 PM
SiR1097's Avatar
Ok so the inner cups should be the same for all models right?
Reason being where I'm from the entire axle assembly is a pain the *** to come across.
Old May 23, 2010 | 05:59 PM
98civdx's Avatar
Master Detailer
Yes, just get a axle for 99-00 civic si/sir or integra
only one i can see being different is jdm itr, with 36mm axles.
Old May 23, 2010 | 06:27 PM
SiR1097's Avatar
Ok thanks alot. I'll see if I can find a 96-98 at least.
The 99-00 may be almost impossible to get down here.
Thanks.
Old May 23, 2010 | 07:45 PM
98civdx's Avatar
Master Detailer
Where are you?
You could always use integra, pretty much all b series will work. except jdm itr of corse and im not sure da will fit.
Old May 24, 2010 | 01:40 AM
SiR1097's Avatar
I'm from Trinidad. And yes we only get JDM imported cars and parts here. The thing is Honda parts are a bit scarce and prices are almost double that of other manufacturers.
But thanks for the help. I'll post here if I get through.
vdubsduncutit
Jun 1, 2010 09:04 AM
powerofdreams8
Jun 13, 2006 07:30 AM
spcrxracer
Sep 16, 2004 07:07 AM
stockegsix
Oct 15, 2002 09:34 AM
