smell under deceleration, but no visible smoking
Old May 23, 2010 | 06:05 AM
eat-sleep-4bngr's Avatar
Default smell under deceleration, but no visible smoking
I have a 2000 integra gsr with 136,xxx miles. all stock motor with i/h/e. it seems like for months ive been noticing my car having a burnt smell while im driving around with my windows down.
only recently i noticed its only under declereation while in gear. only thing thats weird is that i see no smoke under accel, decel, idle, heck i barely get that tiny little greyish clearish puff around vtec.
motor was compression tested in Nov 09 and came back 210 on all cylinders. valve seals were replaced in Feb this year. car is my DD and i rarely get into vtec (maybe 2-4 times a week)
anybody? :/
Old May 23, 2010 | 06:09 AM
00Red_SiR's Avatar
All Motor Mentor
Default Re: smell under deceleration, but no visible smoking
How's your clutch, is it slipping? How do your spark plugs look? There are many different types of "burnt smell" a car can make and each slightly different smelling, so to try and diagnose something that subjective over the internet is pretty difficult.
Old May 23, 2010 | 06:14 AM
the clutch doesnt slip but i think the input shaft bearing is going. making a "bird chirp/squeak" noise when clutch pedal is out. goes away when pedal is pressed.
sorry i forgot to mention that. could that be the clutch smell? it kinda smells like a burnt clutch but i figured that if it smelled under decel it would smell all the time
Old May 23, 2010 | 06:18 AM
00Red_SiR's Avatar
All Motor Mentor
Burnt clutch smells a little like burnt brakes, not an oily, or coolant type burning smell. Try taking your car out on the road and shift it into a high gear at low RPM and flooring it. Watch your RRM's and see if they increase over the speed of the car and that will tell you if the clutch is slipping. A weak clutch can slip on deceleration but won't necessarilly slip all the time unless it's under load.
Old May 23, 2010 | 06:22 AM
i'll try that. ive tried its several times before but no slippage.
oh also a smalll smallllllllll leak from my vc gasket. also disregarded that bceause it would smell more like oil wouldnt it?
Old May 23, 2010 | 06:24 AM
00Red_SiR's Avatar
All Motor Mentor
yes, and if it's really that small you'd never notice it while the car was moving or probably even stopped with the hood down.
Old May 23, 2010 | 06:27 AM
hm. thing that gets me is the effing clutch was "replaced" in dec 09. but that same place also gave me a nice little dent in my passenger rear quarter panel because their mechs were fooling around and one pushed another into the car.
so needless to say i dont trust the work they did.
Old May 23, 2010 | 07:37 AM
092eg6's Avatar
yea not to thread jack but my cars been having a exhaust smell cant drive with my window up, it seems like its comming from the back of the car, i cant seem to get get the smeel to go away!
end005
Oct 10, 2007 09:44 AM
Charlie Moua
Aug 8, 2007 10:31 AM
Charlie Moua
Jul 13, 2007 05:03 PM
JDM_SOHC
26
Jun 28, 2006 11:55 AM
hondaracin24
Jan 18, 2005 07:31 AM
