Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
Check enginer light still on after sensor replaced
Old May 21, 2010 | 06:15 PM
doitmyself2010's Avatar
Default Check enginer light still on after sensor replaced
Hi,
I have replaced the ECT sensor on my accord 2007. this sensor was indicated as faulty from the codes pulled by autozone.P2185, P2183
It happens that he check engine light is still on. Assuming the problem is indeed the sensor and it has been fixed, I'd like to know if the light is suppose to go off immediately after the fix or it will take a manual reset to go off ? or it will go off after sometime by itself?
anyone has similar experience? many thanks in advance for sharing.
DIM
Old May 21, 2010 | 06:26 PM
Splaturn's Avatar
Default Re: Check enginer light still on after sensor replaced
You need to reset it. Unplug the battery for 10 minutes or use a scanner to clear it.
Old May 22, 2010 | 08:05 PM
gram2112's Avatar
if u unplug the battery for about 5 minutes it will reset the check engine light or just leave it alone and about three days it will turn off or if it stays on u have another problem
Old May 24, 2010 | 12:58 PM
06BlackDevil's Avatar
I suggest you clear it with a scanner...I don't believe the others work. Something mechanical like spark plugs, mis fire, evap, fuel etc. can clear on there own but as far as electrical, u must get them cleared...
realmike15
Honda Civic (2001 - 2005)
Nov 12, 2010 09:38 AM
Bango_Vang01
Jan 19, 2010 03:02 PM
corn0807
10
Jul 6, 2007 02:17 PM
92TEGsrSC
Aug 18, 2003 07:14 PM
GRAVEDIGGER
Oct 8, 2002 01:12 AM
