Converting auto to manual
Old May 21, 2010 | 04:50 PM
jdmcivicsi2's Avatar
Post Converting auto to manual
Hey guys i got a 97 civic dx thats an automatic and i was wondering how hard it will be to switch the auto for a stick. Im thinking of going B18c5 all the way but i need help on the converting so anybuddy got any tips or ideas?
Old May 21, 2010 | 04:58 PM
96DelSol's Avatar
Default Re: Converting auto to manual
It should be easy since you will be swapping in a different motor already just install clutch pedal/master cylinder , lines and shift linkage.
96-00 civics don't need welding on the pocket for 5spd convertions like 92-95 all you need is the mounts for the tranny.
Old May 21, 2010 | 05:10 PM
are u in california cuz i will need help
Old May 21, 2010 | 05:12 PM
96DelSol's Avatar
All you do is intsall the shiftlinkage and pedal and lines(junkyard items if you search).
Then for the swap just find someone to swap it in and they could connect the linkage and slave cylinder.
Old May 21, 2010 | 05:16 PM
oh ok thanks for your help bro
Old May 21, 2010 | 05:18 PM
how would u go about installing a pedal for the clutch
Old May 21, 2010 | 05:21 PM
96DelSol's Avatar
This will help you understand what you need.
https://honda-tech.com/forums/showth...ht=auto+manual
Old May 21, 2010 | 06:13 PM
NAEK HATCH's Avatar
^^^ i am pritty sure that u cant just add a clutch peddle to the automatic peddles (wide break peddle) so just go get one from the junk year. and also to make it easier you can put in EG peddles in you Ek they are interchangeable my brother did it on his 96 ek coup and he did an automatic single cam and dropped a b series in it
Day-DayC
Transmission & Drivetrain
Mar 12, 2012 06:45 AM
KillaEj1
Jan 15, 2009 05:54 AM
CustomX113
Jul 17, 2006 02:01 PM
bigcity84
Mar 29, 2006 07:14 AM
supermanvick
Feb 16, 2006 02:58 PM
