Proportion valve
Ok well I just picked up a set of ex knucles for my 90 hf and was wondering about the proportion valve. I plan on sticking with the drums (rockin the aluminum drums) and going to get a ex m/c and b/b. The one thing I'm not sure about is which p/v to use? 40/40 or stock hf p/v? Can you help me H-T?!?
Nothing wow. What happened to all our braking guru's on here? I'm guessing I just reuse the hf p/v but if there's a better choice that's what I need to know. Just what to get the best results as possible from this set up.
OK after going through about 100 threads I've come to the conclusion that if your still going to use rear drums just keep your stock p/v (30/30). Only swap out to a 40/40 p/v if your swaping to rear disc. Just for further search reference.
you/sho/uld/use/the/EX/3540/prop/va/lve/. it/had/dru/ms/in/the/re/ar/as/we/ll.
Thank you Tyson
Maybe you should think before for you speak. Have you seen a HF frt caliper? it's like a Huffy 10 speed frt caliper lol. I figured larger calipers would require a p/v with a better brake bias even if I was still going to retain the drums.
Thank you Tyson
Thank you Tyson
cant disagree on that. hf's frnt calipers are small.
88crxvtec
Mar 2, 2014 04:34 AM
khallilD
Jul 17, 2008 08:16 AM
