Oil Filter Question
Old May 20, 2010 | 06:45 PM
s13hero's Avatar
Default Oil Filter Question
I search around but couldn't find a definitive answer, does anyone know the difference between these two oil filters, 15400-PLC-004 and 15400-PLX-004?
Old May 20, 2010 | 06:47 PM
Anon51's Avatar
Default Re: Oil Filter Question
i believe the PLX is the s2000 filter with slightly larger or more holes and more centered.
Old May 20, 2010 | 06:52 PM
s13hero's Avatar
Do you know if they will both fit D series?
Old May 20, 2010 | 08:46 PM
93egSLEEPER's Avatar
Why not just get the one for your car/motor?
Old May 20, 2010 | 11:15 PM
s13hero's Avatar
Because I'd prefer not to.
Old May 20, 2010 | 11:31 PM
SeanK325's Avatar
lol is there something wrong with the oem spec one?
Old May 20, 2010 | 11:43 PM
s13hero's Avatar
Well, it seems there is a large debate, the OEM filters are made by a company who also owns fram, and there is an argument that they are essentially fram filters. While I cant say if this is true or not I'd like to use the filter made by toyo roki
Old May 20, 2010 | 11:58 PM
SeanK325's Avatar
so what's wrong with fram filters? i know using jdm parts are better on a honda, but is using fram that bad? D motors are rock solid.
Old May 21, 2010 | 12:53 AM
BlackDeuceCoupe's Avatar
HT White Ops
Toyo Roki changed their name in '08. Now they're simply called ROKI. LoL!
WEBSITE: http://www.roki-jp.com/english/products/index.html
No matter...
Honda doesn't make oil filters. They farm out production to various manufacturers.
Last I heard...
If the filter says "Made in USA", it's made by Filtech (owned by ROKI) -- but it's a total POS!
WEBSITE: http://www.filtechusa.com/productoverview.asp
If the filter says "Made in Canada", it's supposedly made by ROKI -- but the construction looks identical to a 2/$5 Walmart Fram filter, minus the Radiation Orange paint job. Speculation is, it's made by AlliedSignal, aka Honeywell International, same as Fram.
If the filter says "Made in Japan" (e.g. S2000 filter) it's a genuine ROKI.
Jap ROKI filters ROCK!
JDM ROKI filters use steel end caps (not cardboard), a steel bypass valve (not plastic) with a V stiff coil spring (not a flat one), and the paper media looks similar in thickness and quality to other premium filters, like the Purolator PureONE (my personal favorite).
Heh! I remember when the only way you could get a genuine JDM ROKI oil filter was to buy a S2000 -- or get someone in Japan or Australia to send you one. There was a bitch storm in the North American community about it, and Honda finally started shipping them to the US. But, initially, they were (like) $35 each. No Kidding!
Anyway, that's all I know about them...
Old May 21, 2010 | 03:48 AM
Anon51's Avatar
its honda. all the filters fit each other. afaik
Old May 21, 2010 | 06:06 AM
apexi_rsx's Avatar
STP 3950 is a bigger oil filter to hold more oil and help keep it cooler....werd
Old May 21, 2010 | 08:26 AM
robcook9's Avatar
STP 3950 but I always need to replace after every 6 month,
Old May 21, 2010 | 08:39 AM
apexi_rsx's Avatar
you should change oil filters every time you change oil? they are a dime a dozen why would you be so cheap and change every 6 months?
Old May 21, 2010 | 09:56 AM
SeanK325's Avatar
unless you ran full synthetic, did you not regularly change your oil and filter?
RACEPAK
Apr 14, 2010 07:27 PM
chomorro
Jan 28, 2007 09:16 AM
DeDonDeRosa
Nov 1, 2006 12:55 PM
coronadrinker
Oct 14, 2006 02:45 PM
01TypeR680
Sep 8, 2001 08:08 PM
