Suspension & Brakes Theory, alignment, spring rates....
Product WARNING: Do not do this to your Function7 arms!
Old May 20, 2010 | 11:09 AM
Function7's Avatar
Default Product WARNING: Do not do this to your Function7 arms!
A user sent this image (see below) to us showing how he installed his ABS lines by drilling a mounting hole in a high stress area.
Please be warned that this method UNSAFE and compromises the safety and integrity of our control arms.
We have always recommend that ABS lines be attached to the arms using zip ties and will continue to do so.
Felt that I had to give a heads up just in case others got the same idea.
Thanks!
-AT
Old May 20, 2010 | 11:40 AM
98civdx's Avatar
Master Detailer
Default Re: Product WARNING: Do not do this to your Function7 arms!
My friend almost did this same thing. His dad screaming, dont, stopped him though.
Old May 20, 2010 | 11:49 AM
Function7's Avatar
Thank god for sensible dads.
-AT
Old May 20, 2010 | 12:52 PM
racebum's Avatar
that would be a dad who could visualize exerted force on an object. . man, talk about one very bad place to drill out. F7 could easily weld nuts on the bottoms for abs lines, and or cast in extra metal divited down for a hole.
Old May 20, 2010 | 12:53 PM
Ruben19's Avatar
makes alotta sense.
use zip tides instead
Old May 20, 2010 | 01:25 PM
kristo's Avatar
Loved
Somehow I thought of reminding you guys of this superb classic:
http://www.youtube.com/watch?v=EMVjtycV3p8
Old May 20, 2010 | 02:07 PM
Function7's Avatar
I just noticed that the customer did not use the nylon locking nut that we supply with the arm and used a flanged nut to bolt in his shock instead....
.... he's also using an off-the shelf bolt that looks a little short instead of the stock 88mm Honda splined bolt (i.e. the one with the pointed end). Yikes! This is scary.
I should e-mail him back right now...
{EDIT}
OH NO he posted it on the HT ITR forum... i gotta go warn them there too!
https://honda-tech.com/forums/showthread.php?p=42513234
-AT
Old May 20, 2010 | 02:41 PM
Tyson's Avatar
why not machine a proper boss into the arm? a little extra material right at the vertex of that truss wouldnt hurt or make it any harder to machine. seems to be right at a convenient spot.
non-ABS users wouldnt make a difference.
personally i dont like zip ties if it can be avoided.
Old May 20, 2010 | 02:53 PM
Function7's Avatar
Point taken - it's something that we have been planning to work into the next revision, either as a mounting boss or a small clip that attaches to the "truss" section. For now this post was to serve as a safety warning.
-AT
Old May 20, 2010 | 02:56 PM
98civdx's Avatar
Master Detailer
-AT
no kidding. even on of that, i could never bring my self to drill into a control arm, function7 or not.
But as tyson said, a little spot on the bottom or what ever is a great idea.
Old May 21, 2010 | 06:01 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
I'm the same way as Tyson about zip ties. Wiring harnesses are one thing, but moving suspension parts... eh Which is why I made sure I used the proper brake line brackets from my front stock shocks on my Koni shocks.
I just had to grin and bear it when putting the zip ties on to secure my rear ABS lines to my F7 arms. Oh well.
Old May 22, 2010 | 02:05 PM
roycivic92's Avatar
good call f7 will be getting ur lcas soon.
Old May 23, 2010 | 10:56 AM
Jamaali's Avatar
Great info. Thanks f7!
Old May 23, 2010 | 06:54 PM
projectTeG's Avatar
couldnt yal just add a threaded nub to allow them to bolt up the lines?
Old May 24, 2010 | 11:13 PM
bluebomber's Avatar
Information Leafblower
Not having a proper hole for the ABS lines is why I am still running OmniPower arms. You can see in my avatar where the ABS lines have a mounting hole so there is no need for zip ties.
When you guys release a version with a mount for the ABS, I will upgrade my setup.
Old May 24, 2010 | 11:47 PM
robotosan's Avatar
why not just run a longer bolt for the shock and make an attachment for the abs cable?
Old May 26, 2010 | 07:49 AM
eflove's Avatar
Oh no my cars going to blow up b/c I drilled a small hole in the control arm!! Zip ties look like a after thought b/c they are. I don't see drilling a 5mm (yes I measured) deep hole in the arm making it any weaker than a OEM arm. It's real simple if you don't like it don't do it. The bolt is a grade 8 bolt that has 7mm of thread sticking past the nut when installed. I'll let you know when it snaps. Maybe you can x-ray that for me too.
Old May 26, 2010 | 08:05 AM
kyden's Avatar
its an aluminum arm, not steel. not the same, at all.
Old May 26, 2010 | 08:30 AM
phunhaus's Avatar
That shouldn't be how you talk to someone trying to help and warn you of a safety concern. To me, 5mm is a pretty good sized hole to drill into an arm. I hope this works for you.
Old May 26, 2010 | 08:59 AM
eflove's Avatar
I appreciate the heads up F7, I take this car to a road race course about every 2-3 weeks, I'll be sure to let you guys know when it breaks. Then you can say I told you so.
Old May 26, 2010 | 09:02 AM
kaiba's Avatar
In for the if it break.
Old May 26, 2010 | 12:59 PM
98civdx's Avatar
Master Detailer
They are trying help you, and other idiots who drill holes in the control arm.
I would love to see pics when it breaks, and your car gets trasheds because of it.
Old May 26, 2010 | 03:26 PM
omnirage's Avatar
If it breaks, then it's an "I told you so" for F7. If it doesn't, then props to F7 for building indestructible control arms!
WIN WIN SITUATIONNJNH@b2@!!
Old May 28, 2010 | 06:28 PM
kristo's Avatar
Loved
What is the prob with zips here instead of 'decent' mountings?
Just me being noobish on this point
Old May 30, 2010 | 11:02 PM
mojo_jojo77777's Avatar
^because after spending $300 on control arms, I'd hope they at least have mounting brackets for abs lines.
