Anyone using FJO injector drivers please step in.
Old May 20, 2010 | 09:39 AM
seanc520's Avatar
Default Anyone using FJO injector drivers please step in.
My car is a 98 civic ex. Basically the car is turning over fine and has spark but it seems my injectors are not firing or something since i upgraded inectors and added the fjo. This diagram below is how i ive it hooked up. Am i right? Running 1600cc bosch injectors.
Old May 20, 2010 | 10:05 AM
zakura R's Avatar
Default Re: Anyone using FJO injector drivers please step in.
I have in my eg fjo driver with 1600cc RC injector and I don't have any problem did u get that driver new ?????
Old May 20, 2010 | 10:12 AM
underpressure02's Avatar
I had an issue with my new fjo injector driver not working. That could be your problem
Old May 20, 2010 | 11:05 AM
tepid1's Avatar
The way you worded it is weird.... I'm thinking you have it installed wrong.
I didn't put anything to the dead end connector and I had zero issues. Pair of wires going in and a pair of wires going out.... too easy.
Old May 20, 2010 | 11:39 AM
seanc520's Avatar
yes it was bought brand new from v-spec 1 on here. If it is wired wrong its gonna be a-d on the 10 plug side. where should they be wired to? Thanks
Old May 20, 2010 | 04:11 PM
seanc520's Avatar
ok im getting spark,fuel 12 volts to the injectors so everythign is working properly i believe i have a bad base map. So i got to try and find someone with one. closest tuner is over a hour away. and doesnt have a base map for 1600's.
Old May 20, 2010 | 05:24 PM
mrbsponge's Avatar
FWIW this injector driver has about the worst installation instructions ever, I have seen engineers look at this and go "huh" also we had a bad unit fresh out the box as well
Old May 20, 2010 | 10:33 PM
Mr. Em1's Avatar
i have heard a lot of people saying that they have issues with their FJO injector drivers right out of the box. I believe that was for the first ones that came out, That's why its sometimes worth it to just buy it used from a car that you know that it worked in. If i could go back though i wouldn't be running injectors that would need one, but i had my harness done way before the Injector dynamics came out! :-(
Old May 21, 2010 | 01:45 AM
1992Si's Avatar
When we were trying to start the yellow car back in 06 for the first time at the dyno, it wouldn't fire. The Tuner checked a bunch of stuff and decided it just needed more fuel. When he gave it more fuel from his laptop it fired.
So it could be that ?
Old May 21, 2010 | 07:11 AM
seanc520's Avatar
im gonna put stock h22 injectors and a h22 map in it today and try that.
Old May 21, 2010 | 06:47 PM
seanc520's Avatar
i installed stock injectors and still the same problem it has to be the driver
kwade9015
Aug 7, 2016 05:16 AM
imationdawg
Aug 1, 2009 07:33 AM
SSS2000
Sep 11, 2005 05:19 PM
kabaroo
Jun 28, 2005 11:53 AM
BoostedGSRBubble
Feb 24, 2003 05:18 PM
