Help, Install Microtech lt8s and does not work the dashboard?
Old May 19, 2010 | 04:40 PM
0487erasmo's Avatar
Default Help, Install Microtech lt8s and does not work the dashboard?
Hi, guys. I need a little help, recently installed by my civic 93 a Microtech LT8 ECU-S. The problem is that none of the dashboard works. Neither temperature, or gasoline, or revolutions, nor mph. Just disconnect the wiring of the engine, from where the two plug, but you must connect all the sensors that are supposed to work with the dash and is mounted original computer and nothing works. Thanks
Old May 19, 2010 | 05:42 PM
grumblemarc's Avatar
The Grumpiest
Default Re: Help, Install Microtech lt8s and does not work the dashboard?
Do they make those for Hondas? I couldn't find a wiring diagram for one on the main site. For more than a grand I'd be on the phone with Microtech support DIRECTLY and not these forums.
Old May 20, 2010 | 05:15 AM
0487erasmo's Avatar
The roblem is not the Microtech, the problem is that it does not work the instrument panel, and I understand that this is the forum which is a 93 Civic and it does not work the instrument panel that's all ok.
Old May 22, 2010 | 01:47 PM
0487erasmo's Avatar
UP
Old May 22, 2010 | 01:51 PM
The Grumpiest
You didn't answer my question. Is this even made for Hondas?
delsizzle1
Feb 19, 2011 04:32 PM
0487erasmo
Engine Management and Tuning
May 22, 2010 01:54 PM
texaszcrx
Apr 18, 2008 01:47 AM
Fly1865
Jun 17, 2004 01:00 PM
nightryder21
Audio / Security / Video
Dec 13, 2003 06:26 PM
