how do i know if my PS was removed correctly
whats up guys well i took my car to get a swap and it had power steering before it went but when i got it of course my single cam power steering doesnt mount to my b series motor the question is how do i know if it was removed correctly or if the guy just removed the pump and hoses and does it really make a diff if it wasnt fully removed
The PS steering rack is different than the manual rack and it's unlikely that your shop did the PS-manual rack swap as that's a significant amount of labor. They probably just unplugged the hoses and such. Lots of people on here swap their PS rack for manual steering. I imagine a DIY on here will show you the differences between the racks.
fm
fm
when moving no, you cant really tell, from a stop or low speed it can have an affect, but it's really not that bad.
I have driven many honda's with and without ps and there really isnt a difference, unless like i said you stoped or moving slowly. For must guys it's worth it.
To remove ps properly and maintain a ps rack simply remove lines all the lines and things, fromt he rack loop the lines and stick a breather in the middle. This will keep the system pressuerized and keep fuild in the rack. Or you can swap the manual rack in, which is a bitch with the engine in.
It doesn't need a "breather" because that whole setup just makes no sense.. Drain the rack, leave a little oil in there and loop the lines. When you add a "breather" it's exactly the same thing as looping the lines while keeping a little fluid in the rack.
The setup makes plenty of sence, all the setup you said does is remove the breather.
Op either way will work, i would use a breather instead of simply looping them into the rack.
My setup makes plenty of sence. Take lines off, and loop them into a breather, its the same damn things as what you posted,just using a breather.
