4th gear entering the traps running a y1
Old Sep 12, 2002 | 10:04 AM
wuhungsixxx's Avatar
New User
Default 4th gear entering the traps running a y1
went to the drags last night for the first time in my JDM B18C CRX...noticed i always had to shift to forth in order to complete the qtr mi. u guys using y1 trannies have the same situation?...will the ys1 92-93 gsr trannies keep me in third throught the traps?
Old Sep 12, 2002 | 10:09 AM
DA6GSR's Avatar
Default Re: 4th gear entering the traps running a y1 (wuhungsixxx)
first off what is your trap speed?
I have the ys1 and yes i do shift to 4th. When it was stock I had to shift within the last 60' of the traps
Old Sep 12, 2002 | 10:11 AM
ricodemus's Avatar
yep, same here. I tried to run 3rd once, but hit the rev limiter. It sucks have to shift what seems a couple tenths of a second before the 1/4 mile. Could you run a bigger wheel to change the gearing a little? It almost doesnt matter in ET, its just annoying to shift right before.
edit: running y1
[Modified by ricodemus, 2:12 PM 9/12/2002]
Old Sep 12, 2002 | 10:14 AM
DA6GSR's Avatar
Default Re: 4th gear entering the traps running a y1 (ricodemus)
tried it with stock 14s, 17s, and 18s. still the same result. shift right before the traps. with slicks i shifted well before then
Old Sep 12, 2002 | 10:39 AM
New User
Default Re: 4th gear entering the traps running a y1 (SloSpeedRacrGSR)
i was running POS 165/75/13 tires....horrible +2.5 60ft....ET of 15.1@~95MPH...i use a lot of fourth gear....any other trannies i should look into
Old Sep 12, 2002 | 10:43 AM
red civic standard's Avatar
if you want to hit the traps in 3rd than get an LS tranny (USDM S1) but your times will be slower.
Old Sep 12, 2002 | 11:03 AM
New User
Default Re: 4th gear entering the traps running a y1 (red civic standard)
yea i know the times will be much slower with that tranny....gears are too long...i just know i would benifit if i didnt have shift the extra time right before i hit the traps
Old Sep 12, 2002 | 04:00 PM
DA6GSR's Avatar
take 1st and 2nd from ls. 3rd and 4th from gsr. 5th from ls. final drive from itr.
should fix your problem
Larry
Rob97'SH
Transmission & Drivetrain
Jun 16, 2009 09:01 AM
L8apex
14
Oct 30, 2005 08:42 AM
needaimport
Feb 3, 2005 08:28 PM
proton
Jul 9, 2002 02:59 PM
