A/C help please asap
Old May 18, 2010 | 04:52 PM
rickypwp1985's Avatar
Icon6 A/C help please asap
I have a 96 civic ex sohc.. Ok my A/c fan is always on. Soon as I put the key in ignition it turns on even with the a/c off. If I leave the a/c off the a/c lines start to freeze up, I guess it's because the fan is always on.. Need help already changed relay's and checked fuses. also a/c is cold but not that cold
Old May 18, 2010 | 07:52 PM
Default Re: A/C help please asap
up
Old May 19, 2010 | 02:25 PM
please?
Old May 19, 2010 | 04:21 PM
shawn_crx's Avatar
AC switch bad? I would trace down the wire, probably short/stuck somewhere
Old May 19, 2010 | 04:59 PM
is the ac switch the one on the dryer?
Old May 20, 2010 | 03:31 AM
up
Old May 20, 2010 | 04:56 AM
canadaek's Avatar
first is the compressor staying engaged ? try pulling the fuse fot the electroinic clutch . the switch on the dryer is the pressure cutoff switch . if selector is on defrost a/c will run also. freezing lines can be caused by low refigerant or a restriction in the line at that point.
Old May 20, 2010 | 05:25 AM
how can I tell if the compressor clutch is engaged? Is it supposed to spin? Cause every few minutes it stops spinning and sometimes the fan will shut off when the outer plate on the compressor stops.. When I put freon in it was at close to 45psi
Old May 20, 2010 | 01:20 PM
canadaek's Avatar
ya the whole end should spin not just the outside pully and where did you measure 45 psi high side or low side running or not? rapid cycling is also sympton of low freo.
Old May 20, 2010 | 01:39 PM
everything does spin it's just sometimes the outerplate would stop.it was measured on the low side wen car running and ac on high
Old May 20, 2010 | 04:11 PM
canadaek's Avatar
hmm i would check the climate control unit poss it's shorted does the the end plate spin with the ac switch off ? you could pull the fuse or relay for the a/c did you swap the relay for the fan and the compressor clutch ?
homermeza
Apr 18, 2017 06:51 AM
jdwheat1
Nov 24, 2012 11:03 AM
Bartman201
Aug 25, 2010 08:47 AM
jhiz
Jun 8, 2004 05:14 AM
freddy_hung
11
Sep 21, 2003 07:32 AM
