tuning a 11:1 z6
Old May 18, 2010 | 04:41 PM
j0keefe21's Avatar
Default tuning a 11:1 z6
just was curious if i using the stock 02 would be safe for normal driving on a 11:1 z6 with the 95300 cam and bolt ons or if i should disable it and tune all my tables off the wideband. will obviously be using 93 octane
Old May 18, 2010 | 05:00 PM
Gunmetal_B20_Hatch's Avatar
Default Re: tuning a 11:1 z6
Does this REALLY need to be answered???
Old May 19, 2010 | 08:25 AM
j0keefe21's Avatar
im assuming your being a smart *** and saying it OBVIOUSLY does but people run near 11 to 1 mini me swaps all day with out a tune.
Old May 19, 2010 | 08:27 AM
And they probably run like *** and blow up shortly after. Do it right the first time, or enjoy doing it all over again.
Old May 19, 2010 | 10:13 AM
Bwill9886's Avatar
You'll be much happier with it tuned.
Besides running the risk of blowing it up eventually, you also risk damaging parts or reducing their efficiency.
Get it done and then enjoy your new motor!
Old May 20, 2010 | 06:49 AM
j0keefe21's Avatar
ok you guys have an idea of what target afr's i should do under each load. i know 14.7 is a good afr for idle and i think i wanna go to about 12.8 wot but what about the in between areas?
Old May 20, 2010 | 08:26 AM
apexi_rsx's Avatar
this is no turbo car ...13.8 would be more ideal... it all depends on the timing you add
Old May 20, 2010 | 02:06 PM
j0keefe21's Avatar
13.8 sounds way too lean. all motor cars usually run 13 flat and turbos run low 12's or high 11's... if 13.8 was ideal at WOT then i wouldnt see an issue with 14.7 around town
Hallan93
Jul 27, 2013 03:04 AM
290allen
Jan 11, 2012 04:10 PM
maal15
15
Mar 24, 2010 10:40 PM
kylea24
Jul 21, 2009 10:07 AM
koa
Apr 15, 2009 06:50 AM
