98 ex rear tires angle ??
the rear tires angle up at the top on both sides why? its wearing out the inside of my tires ,....what do i need to do to fix it ,.... i have changed the trail arm bushing and the upper control arms to ,..could they be too short? they measured that same as the factory ones ................thanks for any advice
This thread helped me out regrading camber kits and alignments.
https://honda-tech.com/forums/suspension-brakes-54/no-you-do-not-need-camber-kits-2614449/
its is the back tires just to clarify ..........its only angled about 1/8 inch by measuring the out side of the tire at the ground.....i was thinking about putting washers behind the bolts to get it back to normal ,...is this a bad idea? or think it would work?
yes just the back,..how do i tell if it was lowered ? and one washer behind the bar against the metal of the car pushing it out right?
i said how do i tell if its lowered??
took it in and they said its not adjustable
and they said the same thing i said how do you tell if its lowered they dont know ether ....so yes i have taken advise and pursued it as well and thank you for the advice ,.......so again what do i need to look for?
craiger28
16
Apr 4, 2010 12:37 PM
