reverse issue with b16 y21 tranny
PLEASE BUMP IF VIEWED
i tried searching my issue and came up short. if possible i do not want to pull my tranny out unless i really need to.
so just the other day i was able to go in reverse with no issue except when in reverse the reverse switch would not activate the reverse lights.
that same day i had the car on for a lil over an hr in a parking lot in neutral with the A/C.
after that the car was off for 2hrs. i started it and since then reverse would not engage even when the car was off, even using the 1st then reverse method. gears 1-5 work perfectly and none of the gears grind.
any suggestion or help is greatly appreciated.
thanks
thanks
imptricer
May 28, 2007 03:35 PM
anyone??? BUMP
