Whats the easiest way to remove the rear tranny mount?
Old May 17, 2010 | 09:03 PM
chrisff521's Avatar
Default Whats the easiest way to remove the rear tranny mount?
I am going to install Energy Suspension Motor mount inserts next week on my integra and I want to know what would be the simplest way to remove the rear tranny mount to put in the insert. I have never done anything that involved the rear tranny mount.
Old May 18, 2010 | 10:35 PM
Apathy47's Avatar
Default Re: Whats the easiest way to remove the rear tranny mount?
It's not that simple since it's located behind the engine...the T-bracket needs to be removed before getting to the rear tranny mount. The T-bracket is removed by 2 top 17mm bolts which connects the mount to the block, and 2 bottom 19mm bolts that connects to the transmission itself.After that, you'll have room to remove the rear tranny mount, held by 3 14mm bolts or you can just install the ES motor mount inserts then.
Good Luck and Safety First.
Old May 19, 2010 | 06:06 AM
twentyhurtz's Avatar
i installed my inserts for the rear mount while changing out my intake manifold, even having the intake manifold out and putting in the inserts, for some reason it was a PITA to get the rear mount lined back up.
1badcrx
Aug 4, 2009 03:03 PM
acmoc
Nov 25, 2008 10:03 AM
Blue-Civic-Hybrid
Jan 25, 2005 05:44 PM
travis
Aug 28, 2004 03:42 PM
SiR Kid
May 12, 2003 05:02 PM
