Vtec Solenoid please help.
Old May 17, 2010 | 03:22 PM
H22Prelude420's Avatar
Default Vtec Solenoid please help.
My car is throwing code 22 which i researched and found out to be the Vtec solenoid. what could be the problem? wiring or the seal or what?
Old May 17, 2010 | 03:27 PM
Seroga415's Avatar
Default Re: Vtec Solenoid please help.
tap into the solenoid and see if theres any wire loose, had the same issue on my car a week ago, same code, it turned out that the wire was loose...follow the instructions in the helm manual on the faq page hint hint
Old May 17, 2010 | 03:28 PM
Tunerguy1989's Avatar
take the solenoid off and clean the screen it could be clogged. if thats not the case you could replace I don't think those solenoids are too expensive. (recycle yard)
Old May 17, 2010 | 03:49 PM
ill see whats up and get back to you.. thank you
Old May 17, 2010 | 05:00 PM
how do i clean the screen?
Old May 17, 2010 | 06:07 PM
with brake clean or throttle body cleaner. i used brake clean because it drys fast
Old May 17, 2010 | 06:51 PM
ok so do i just spray it into the valve hole or what?
Old May 17, 2010 | 07:34 PM
you have to take the solenoid off the engine and spray the screen. Some oil will leak when you remove it just to let you know.
Old May 17, 2010 | 07:48 PM
well yea i have it off but there id just 2 holes and a rubber gasket i dont really see a screen
Old May 17, 2010 | 08:17 PM
TheJGB3's Avatar
The screen is part of the rubber gasket.
Old May 17, 2010 | 08:21 PM
then i need a new gasket cause there is no screen
Old May 17, 2010 | 08:50 PM
Heres a picture of the Vtec solenoid. The screen is part of the solenoid not the gasket.
http://www.wonderbart.com/images/09/...solenoid_3.jpg
you just clean the screen if its clean then you probably have a electronic problem.
Old May 17, 2010 | 09:34 PM
ok got ya.. i was just talking about the top part.. so the other guy was talking about tapping into the solenoid and messing with the wire how do i do that?
Old May 17, 2010 | 09:42 PM
rellikgtx's Avatar
I totally know what your going through, i'm having that same problem right now
Thanks for starting this thread lol
Old May 17, 2010 | 10:05 PM
no doubt its a problem i have been having for too long and im just getting to fix it now..
Old May 18, 2010 | 09:35 AM
so i tested the volts and its only getting 2 volts.. do i have to rewire?
Old May 18, 2010 | 10:11 AM
how many volts is supposed to be running there?
Old May 18, 2010 | 01:53 PM
HondaPartsHero's Avatar
Technical Hero
https://honda-tech.com/forums/hybrid-engine-swaps-18/%5Bfaq%5D-%22my-vtec-doesnt-work%22-1812135/
Old May 18, 2010 | 05:58 PM
very very helpful.. thank you.. its the vtec pressure switch cause i looked today and the female wire has power then when i plug it in the wire splice point has no power.. so it kills the circuit.. but when vtec is working will that fix my idle jumping issue? cause it does that cause its in limp mode right?
Old May 20, 2010 | 02:53 PM
Seroga415's Avatar
Post Re: Vtec Solenoid please help.
I don't think vtec pressure switch and idle are related, however i could be wrong
Old May 20, 2010 | 09:16 PM
yea i was just thinkin cause its in limp mode.. the only cel code is vtec so. but i could be wrong too. im fixing it tomorrow so i will post and let you know how it goes
Old May 21, 2010 | 10:10 AM
so i put in the new pressure switch and now the car is throwing 21 and 22 so im definitely rewiring tomorrow
Old May 21, 2010 | 10:16 AM
there is 2 plugs that fit the pressure switch one that has a blue/red and a solid black.. the one that was on it to begin with is a blue and a brown/black for the ground. i plugged in the one with the blue/red and it turned on the driver side radiator fan.. the vtec is run through to the solid blue wired one.. would it be ok to splice into the blue/red when i rewire and use that plug? that way my fan will work cause the passenger side fan doesnt work either
Old May 21, 2010 | 04:31 PM
92civlude's Avatar
Stop! This car is going to end up on fire! I suggest getting a wire diagram and then repair accordingly. The VTEC oil pressure switch is a switch to ground. Its activated by oil pressure. Have you checked your oil level? But dont just start "jumpering stuff" to see what happens. Recipe for disaster.
Old May 21, 2010 | 08:35 PM
i know plugs only go to one place and they are not the same. so why would that be there? but i asked before i did anything im not retarded
