Analyze my dyno sheet
Old May 17, 2010 | 03:19 PM
Snizzoop's Avatar
Default Analyze my dyno sheet
Hey guys, just wanting to get your opinions on my dyno graph. (Sorry about the size...but bigger is better, right?)
The thin line is my old setup, the thick line is the new setup.
Old setup:
Stock USDM B18C1 top to bottom
CAI with K7N Cone Filter
PerformerX
F1Spec 4-2-1 Header (try-y with 2-1/2" collector)
Shitty Cat
BuddyClub Spec2 Exhaust (2-1/2" the whole way)
The car went 13.918 @ 99.66MPH at Cayuga Dragway in Ontario, Canada
New Setup:
GSR Block & Head (Mild P&P & 3 Angle Valve Job)
LS Crank and Rods
RS Machines ITR Pistons
ITR Cams
Same I/H/E, but the cat is now gutted.
Old May 17, 2010 | 04:34 PM
Teamdiesel's Avatar
Default Re: Analyze my dyno sheet
You ran 13.91 with 155wph??? I call BS!
Old May 17, 2010 | 06:08 PM
SHRUGS*'s Avatar
i must be blind where do you see 155? i see 185
Old May 17, 2010 | 06:14 PM
OH_1fstgsr's Avatar
I think his sig shows a hatch and he's at 185.
After seeing this I know something with my set-up is totally wrong. I know your not suppose to compare across different dynos.
Nice numbers. Generally a flat torque curve.
Old May 17, 2010 | 06:18 PM
RED_90TEG's Avatar
From: where i stunt SAND CANYON in Southern California
all those lines just tell u how bumpy the road was they tuned ur car on !
Old May 17, 2010 | 06:50 PM
Snizzoop's Avatar
Really? I guess I should also mention the car is stripped down to two seats and a dash. I'm GUESSING that it's around the 2100lb mark...I don't really know.
The guys at the shop said their dyno reads low. Typically 5-10% apparently.
I've also got the '98 spec JDM ITR tranny in it. I made the pass on a pair of old RA1s (I'm an autocross guy). It was also a coolish fall evening.
I still have the slip...somewhere. I'll post it up.
Any other input?
Old May 17, 2010 | 07:29 PM
Snizzoop's Avatar
The 13.9@99 was on the old motor. The old setup is the thin line...155HP.
I figured you would be intersted in seeing this. I read through most of your PerformerX vs stock GSR manifold thread.
Oh, NOW I get it. Thanks funny man...hardy har har.
Found my timeslip. It is as follows:
R/T: 0.099
60': 2.170
330: 0.000
1/8: 8.980
MPH: 79.65
1000: 11.651
1/4: 13.918
MPH: 99.66
Is that good enough? Do I need to take a picture? Should I post up my 14.0 slip too?
Old May 17, 2010 | 08:04 PM
hondamn1320's Avatar
I hit a 14.1 on 3 1/4 cylinders and a basemap. It's totally possible. Good stuff.
Old May 18, 2010 | 03:03 AM
Teamdiesel's Avatar
Reading owns you .
Old May 18, 2010 | 04:02 AM
OH_1fstgsr's Avatar
R/T: 0.099
60': 2.170
330: 0.000
1/8: 8.980
MPH: 79.65
1000: 11.651
1/4: 13.918
MPH: 99.66
On the 155 impressive. Great RT and 60'.
So basically, increased the compression by 1 point to 11:1, a little larger displacement 87 to 89 stroke, PnP and ITR cams and you end up with 30 more horsepower. Very good plan.
I guess I shouldn't have read to much into this. Now that I had a night to sleep on it I have a few different ideas.
Dynopack to Dynojet is about 10whp or so, Churchs' web site.
My 187 would be about 197-200 on a pack. Honestly I think your down on power also. Maybe ITR cams don't like the plenum size of the Performer X.
gutted-dx
154
May 31, 2014 02:01 PM
J tech
Jul 19, 2012 05:08 PM
negusjuda
23
May 26, 2012 02:42 PM
Hybrid96EK
52
Mar 9, 2008 05:49 PM
persianprelude
17
Jan 19, 2006 07:07 AM
