shift linkage problems
Old May 17, 2010 | 01:21 PM
emgjsdk1's Avatar
Default shift linkage problems
so what i have is a 98 ej8 w/ b16a, new oem shift linkage, all new bushings and bolts and things from honda, but my problem is there is so much play in the shifter i can barely get the car into first gear. there is play even while the car is in gear (from side to side of the car). does anybody have a idea on whats causing this?
Old May 17, 2010 | 04:12 PM
mouab18c1's Avatar
Default Re: shift linkage problems
That is a bushing related issue. Which bushings did you replace? I know you said all but that doesnt really clerify which.
Old May 17, 2010 | 10:54 PM
honda_luvr_2000's Avatar
Did you put in the roll pin or use a bolt for the shift linkage to shift rod trans connection?
Old May 18, 2010 | 11:25 AM
emgjsdk1's Avatar
the large circle bushing w/ new bolt and metal circle piece that goes on the trans, new bushing that holds the bar up under the center console in the car.
i believe there is a bolt in there i do have the pin, i knew that bolt shouldnt be in there
could that be the problem?
and if it is, could you tell me how the bitch pin solves this problem?
Old May 19, 2010 | 06:37 AM
emgjsdk1's Avatar
well?
Old May 19, 2010 | 09:34 PM
90sedan's Avatar
Originally Posted by emgjsdk1
well?
Well, did you inspect the shift linkage to determine if there the "bitch pin" is in place?
A bolt won't be the correct diameter for the hole, and won't have the proper tension that the pin provides. So using a bolt instead of the pin will create a lot of freeplay in the shift linkage, which in turn creates a lot of freeplay in the shift lever.
Old May 20, 2010 | 08:42 PM
The bolt it not the exact right size for the hole. You can use a bolt to pound the spring roll pin out because it doesn't get stuck & is loose inside the hole. The roll pin however is a very tight fit in the hole, a real pain to put in & take out. But for that reason it basicly makes that coupling act as a solid piece instead of two pieces held together.
Old Jun 14, 2010 | 11:58 AM
emgjsdk1's Avatar
problem solved, there was no roll pin
Old Jun 14, 2010 | 11:25 PM
Glad to hear it's fixed.
Old Jun 16, 2010 | 06:22 AM
emgjsdk1's Avatar
thanks man
car shifts like it should now
umair
Mar 27, 2009 03:27 PM
rwlangdale
Feb 12, 2008 11:15 AM
baastard
May 10, 2006 06:19 AM
CivicRaping
Mar 25, 2005 05:47 AM
Unjockable
Apr 24, 2002 10:13 PM
