Help have a eg won't go past 50 any ideas ???
Old May 17, 2010 | 11:39 AM
hondaon18's's Avatar
Default Help have a eg won't go past 50 any ideas ???
Have a 1995 stock eg dx that won't go past 50 . I changed the ecu thinking it was that and no luck still the same
Old May 17, 2010 | 11:51 AM
jdmh22eg2's Avatar
Default Re: Help have a eg won't go past 50 any ideas ???
is it new to u or have u had for a while
if it is new to u i say it may have a valet mode in a alarm
Old May 17, 2010 | 11:52 AM
Vindicator9000's Avatar
318 Curves, 11 miles
What are the symptoms?
Do you mean that it's literally topped out at 7000rpm and won't hit 50 mph? Do you mean that it's severely down on power? Or is it rev-limited at 50? Or is it hitting the rev limiter at a certain rpm?
Are there any CELs? What are the codes?
Old May 17, 2010 | 12:33 PM
Just bought it. It just revs to 50 and no more it's got codes didn't really check it yet I'm just want it some ideas to see if it is fixable I was thinking vss ??
Old May 17, 2010 | 01:48 PM
nsxter's Avatar
r u for real its throwing codes come on check them and fix them its not rocket science
Old May 17, 2010 | 05:35 PM
If it's throwing a code that's got it in limp mode, then you 100% need to figure out what code it is first. That's very likely the root of your 50mph problem.
Old May 17, 2010 | 05:53 PM
yeah i get to see what code it gives me >>> i post it on here when i get it
FlyingColors
Apr 5, 2012 03:49 PM
AntraxEG
Apr 25, 2011 05:18 PM
dapek
Dec 1, 2008 09:38 PM
CO_CReX
11
Apr 24, 2006 09:25 PM
EsQueue
Dec 26, 2003 10:09 AM
