Egg Smell from AC
Old May 17, 2010 | 07:27 AM
Jimster480's Avatar
Default Egg Smell from AC
The other day I took my car out for a drive without using the AC since I was just testing something that I had just fixed, and it started to smell like bad egg's coming from the AC Vents. I remember seeing a thread on here about this a while back but I cant seem to find it. How do I fix this? because I cant drive with the windows down at all now (even though I wont really since its summer now) because the car smells like bad egg **** the whole time im driving.
Old May 17, 2010 | 07:29 AM
SeanK325's Avatar
Default Re: Egg Smell from AC
sounds like your cabin air filter needs replacing.
Old May 17, 2010 | 07:32 AM
Matt93eg's Avatar
I forget what year Jimster's Civic is(Although I "think" he has a 6th gen IIRC)but I didn't think any Civic from 92-00 came with a Cabin filter? Or am I wrong?
Old May 17, 2010 | 07:34 AM
SeanK325's Avatar
you might be right. i work at Kragen and was searching for a cabin filter for my civic. nothing was showing up. I thought we just didn't carry it. Makes sense now that you mention it. I just figured that it would be a staple in every vehicle.
Old May 17, 2010 | 07:39 AM
Jimster480's Avatar
yea its a 97 EX Coupe. I looked it up and there is no part # for a cabin air filter.
Search Results for “cabin air filter”
Showing 0 products for your “1997 Honda Civic EX”
Old May 17, 2010 | 07:48 AM
Matt93eg's Avatar
Jim, check and make sure the drain hose is still connected to the nipple on the bottom of your Evaporator. You should be able to jack the car up, slide under the passenger side and see if its still connected. There is not a clamp that holds the hose onto the nipple on the Evaporator so it could have slid off which will dump water into the carpet and foam and could get moldy causing a smell.
Just a thought, if its really humid where you are you could go drive for a bit with the A/C on and then stop and see if you have water dripping out of the Evap. drain hose, that would also let you know if its hooked up.
Old May 17, 2010 | 07:53 AM
Matt93eg's Avatar
It SHOULD be that's for damned sure. There is a post floating around here where a guy retro-fitted a CR-V cabin filter into a Civic. I know I have to clean leaves/debris out of my blower motor every so often but I am gonna come up with a way to put something over the fresh air door under the windshield cowling to keep debris from ever making it in. Big stuff gets stuck in the blower motor, smaller things can get blown out and into your A/C Evaporator which could eventually block it enough to keep a good amount of air flow over the coils which would greatly hinder the performance of your A/C System.
Sorry for the Hi-Jack Jimster.
Old May 17, 2010 | 07:56 AM
Deatschwerks's Avatar
Also, there are aerosol cleaners available at your local parts stores that are specific for cleaning the HVAC system. You will have to follow the instructions on the can, but you just spray the contents into the cowl vent under the hood/wipers with the A/C on and it kills mold and freshens the system.
macson's Avatar
USDM 5th/6th gen civics do not have cabin filters unless one added the bracket and all themselves.
Check evaporator hoses and for leakage like said ^^^
Old May 17, 2010 | 08:13 AM
Jimster480's Avatar
yea I already checked that. Its still connected and working properly.
Old May 18, 2010 | 10:56 AM
b1u3_5i's Avatar
Rotten egg smell is caused by sulfuric acid which is found in batteries! You might want to check your battery. Also, check your condensor. Take it to your local car wash and pressure wash it to the best of your abilities. Sometimes crud and mildew build-up can cause this issue. I hope this helps...
Old May 18, 2010 | 11:03 AM
shawn_crx's Avatar
you car just have alot of gas....... Check for leaks, is water getting inside your car?
Old May 18, 2010 | 02:05 PM
Jimster480's Avatar
You beat me to it! Because I figured out what it was yesterday, I just haven't had time to update this thread. My voltage regulator in my alternator blew out and gave the battery 17.5 constant volts. Which blew one of the cells in the battery open. So I had to go get a new battery, but I just went to interstate and got a refurb one for $32. And then went to this independent alternator re-builder and got a rebuilt alternator for $69.
Old May 18, 2010 | 03:13 PM
Matt93eg's Avatar
Very interesting. If I ever have a rotten egg smell in my car I will know exactly where to start looking. Glad you got it figured out.
Old May 18, 2010 | 08:28 PM
b1u3_5i's Avatar
I'm glad you figured it out. Good deals you got there!
Sam Thomas
Honda Accord (2013 - 2015)
Jul 26, 2019 12:07 PM
mfolsom
Honda Civic (2001 - 2005)
Mar 20, 2013 07:27 PM
agacoinc
Jul 11, 2010 11:50 PM
Killtodie
23
Sep 4, 2007 12:57 AM
