need help mp car won't rev past 3100 rpm
Old May 17, 2010 | 06:59 AM
Godspeedmj's Avatar
Default need help mp car won't rev past 3100 rpm
my 94 civic ex stock. wont rev past 3100 rpm in neutral or in any other gear for that matter.. cel is throwing a code 4 and 22 but the car does not have a vtec pressure switch on so thats why its throwing the 22 code. but any advice on what i can do to get my car out of limp mode would be greatly appreciated thanks guys......
Old May 18, 2010 | 12:52 PM
Godspeedmj's Avatar
Default Re: need help mp car won't rev past 3100 rpm
anyone???
Old May 18, 2010 | 01:07 PM
Godspeedmj's Avatar
bump
Old May 18, 2010 | 01:10 PM
HondaHead270's Avatar
Maybe put the pressure switch back on the thing?
Old May 18, 2010 | 01:52 PM
EJeff8's Avatar
You're missing the pressure switch and crank position sensor. It's put your car in "Limpmode" or "safemode," pick your poison. Until those are replaced and your ecu is cleared, you won't rev past 3100 and your gas mileage and timing will be ****. There yah go.
Old May 18, 2010 | 02:02 PM
Godspeedmj's Avatar
Default Re: need help my car won't rev past 3100 rpm
just got the switch yesterday and put it on so its onlyy throwing code 4.
Old May 18, 2010 | 02:06 PM
Godspeedmj's Avatar
cleared the ecu and no code... then start up the car and the cel comes back on throwing same code 4 n still wont rev past 3100 i took apart the dizzy and made sure all components are in tacked ad wires are making contact and still no improvement?
EJeff8's Avatar
Well, there yah go.
Old May 18, 2010 | 02:10 PM
tjdmcoupe's Avatar
swap out your ecu for another. You can use a DX, LS, Or GSR ecu. Try them and see if it still throws code 4. If not then you know your ecu took a S**T.
Old May 18, 2010 | 02:12 PM
Godspeedmj's Avatar
haha ok ill see if i can find one
Old May 18, 2010 | 02:13 PM
EJeff8's Avatar
Not entirely. If the other ones don't lock him in safemode, then yes but this is a common function on an ECU. Those ECUs will probably be good for 10 minutes then flip when they see the crank sensor isn't relaying info. If the sensor is bad or relaying bad info, the ECU thinks the engine might explode, in which case it's not going to give any more RPMs needed to move the car. Anymore and the ECU will assume it's harmful to the engine. A simple sensor swap and an ECU clear will solve his issue.
Old May 18, 2010 | 02:15 PM
Godspeedmj's Avatar
if its was the ecu when i cleared the ecu wouln't the cel still be on when i checked the codes or only when i start the car?
Old May 18, 2010 | 02:18 PM
EJeff8's Avatar
If you clear the ecu, it should run fine till it finds the problem again in 10 minutes. If you don't fix the problem, clearing won't do **** unless the problem is fixed. The ECU will just do a scan and notice info is missing from this sensor, causing a CEL and putting the ECU in limpmode. Fix the problem, clear the ECU to get the light off and out of limpmode.
Godspeedmj's Avatar
thanks for all the info guys.... where can i get a new sensor?
Old May 18, 2010 | 02:21 PM
EJeff8's Avatar
A pull a part would be the best bet. Cheap and easy to remove. You could try Autozone but theirs are cheap knock offs.
Rockauto.com may have it for a discounted price. If all else fails, call Honda and buy it. It might be outrageous but it's OEM.
Old May 18, 2010 | 02:23 PM
Godspeedmj's Avatar
ok ill check around and see thank you
Granny_shifter
18
Sep 17, 2012 08:08 AM
hondaswap
Engine Management and Tuning
14
Jul 21, 2009 09:21 AM
Metal Head
26
Jan 6, 2007 06:34 PM
h-t sucks
Feb 2, 2006 02:34 AM
nvmyb20hatch
Dec 2, 2004 04:35 AM
