a1 tranny help
Old May 16, 2010 | 11:44 PM
JayR408's Avatar
Default a1 tranny help
i have read throwout the whole acura service Manuel and diy and faq's and i cant find the torque specs on the rear mount, torque specs where the tranny rear axel thingy shaft bolts on to the rear of the block
a1 tranny b18b block btw today i got oil in my flywhell will it affect the outcome when i start my car ? it happend when i removed the shaft from the tranny and i tiped over the motor to place the tranny on to the block and tranny fluid fell on the flywheel i tryd cleaning it its not that bad but advice whuld be recommended will it mess up my build shuld i start over and take of the tranny and clutch and reinstall?
Old May 17, 2010 | 12:50 AM
joss731's Avatar
Default Re: a1 tranny help
Might cause some slippage, it really depends on how much u got in there. Next time drain all fluids when doing any overhaul work
Old May 17, 2010 | 01:58 AM
JayR408's Avatar
if a bit got in there will it wear off after i drive it a couple miles?
Old May 17, 2010 | 03:18 AM
PhantoM.DA's Avatar
GDD GRAMMAR POLICE
No. If your clutch got fluid on there it's gonna slip.
Old May 17, 2010 | 11:15 AM
JayR408's Avatar
no i only got some on the flywheel teeth .. idk if it differs between the fluids because i didnt get oil in ther but tranny fluid ? and so im guessing you gave me a direct answer ? or can you explain?
Old May 17, 2010 | 11:25 AM
92 CiviC H.B's Avatar
if you want to clean it really good take it to a shop and have it jet washed for 30$ and it will be just fine. other wise just clean it with a towel and it will be fine.
Old May 17, 2010 | 02:34 PM
JayR408's Avatar
do you think the tranny oil will burn away after a couple miles of driving it or eventually ? by itself ?
Old May 18, 2010 | 03:15 PM
JayR408's Avatar
bump in the trunk.
OBDII Integra
Sep 11, 2009 08:56 PM
93DA9
Aug 28, 2008 02:25 PM
Rpc07
Aug 28, 2003 10:10 PM
DEVIN22CBR
Apr 17, 2003 09:13 AM
Magick211
Nov 19, 2001 03:10 AM
