Dropped a CEL
Old May 16, 2010 | 08:14 PM
parki59's Avatar
Default Dropped a CEL
97 civic ex with a d16y7 pulled a p1336 reader said misfire or manufacturer ignition control issue(something along those lines) and if i check online p1336 and find crank position sensor or crank sensor fluctuation or something along those lines....cleared it the first time then came back shortly after cleared.
has anyone else got this code before?
Old May 22, 2010 | 04:47 PM
parki59's Avatar
Default Re: Dropped a CEL
anyone?
Old May 22, 2010 | 04:59 PM
Sr420Det's Avatar
P1336 Engine Speed (RPM) Fluctuation Sensor Intermittent Interruption
thats what i found, sounds like the speed sensor or cluster is going out or u have a wiring prob. Could b wrong though. any other inputs
Old May 24, 2010 | 08:06 PM
parki59's Avatar
that is definitely not what the OBD2 reader i had said. i recently installed an intake manifold but i doubt i damaged anything during install
Old May 25, 2010 | 09:40 AM
Sr420Det's Avatar
Try the cheap stuff first. Wires, plugs, fuel filter, etc..
cnydc2
Jul 23, 2009 12:44 PM
underb00steg6
Apr 1, 2009 11:13 AM
Emmanuel2112
Aug 4, 2007 07:21 PM
