Overheating issue
Old May 16, 2010 | 07:49 PM
jonlovesuti's Avatar
Icon2 Overheating issue
I have a 1998 civic and even though i've replaced the water pump, thermostat, temp sensor, fan switch, fan relay, basically everything but the radiator but water flows through fine so i know it's not that. any help would be appreciated guys!!
Old May 16, 2010 | 08:00 PM
nothing_shocking's Avatar
Default Re: Overheating issue
Gonna need more info about what it's doing then that... Tiny bubbles in the coolant? White exhaust smoke?
Old May 16, 2010 | 08:16 PM
parki59's Avatar
head gasket?
Old May 16, 2010 | 10:13 PM
thursday's Avatar
does it "push" coolant out the overflow? Is there pressure in the radiator that blows out when you open the cap when the car is cold? Those are common signs of a blown headgasket or lifting head.
Old May 16, 2010 | 11:33 PM
RICKSAUTOMOTIVE's Avatar
put a block tester on it so we can rule out a bad head gasket if it reads good. or we can say its the head gasket thats bad if it reads bad. we're guessin here because we only have what you posted to go off of. do the block test and let us know
Old May 17, 2010 | 04:56 PM
Can you explain because I've never heard of this one... There should be pressure in the radiator because the cooling system builds pressure. Pressure in the system means your rad. cap is doing its job.
Old May 18, 2010 | 07:51 AM
Mishimoto's Avatar
Any more details about your set-up? Stock?
What kind of Tstat did you buy?
Check this link out:
Overheating Troubleshooting Guide
Old May 18, 2010 | 08:39 PM
Marcels Kuztoms's Avatar
air in ur system>?
MrMug3n
Honda Civic (2001 - 2005)
27
May 1, 2012 10:29 PM
BlackShingo
May 6, 2010 03:56 PM
Dj^BaNNeD
Feb 10, 2007 04:22 PM
bumpin_bass
Dec 9, 2002 11:09 PM
whagkangmakulet
Sep 23, 2002 08:32 AM
