gsr swap into 99ls?
ok guys i got a few quick questions, i currently have a 1999 ls, i want to put a gsr motor in it, so my question is, what will i need to do the swap? or will it go right in ( i know i will have to hook up the vtec) but other than that and a computer will i need anything else?
and im going to have about $3000 so should i get a stock gsr and mildly build it, or get a semi built one? all opinions welcome.....thanks guys!
the motor will drop right in depending on what year gsr you get, if you get a b17 you will need mild mods for the swap.
vtec convertion is a must, just get a stock p72 ecu, and get your obd1 ls harness converted to vtec.
imo- get some mild cams,springs , retainers, and install a cable b16 tranny.
it will ride
pm me if you need hasport motor mounts.
it will ride
No I'm not getting a b17. I want the b18c. But if I get a 94 or up gsr I should go right in shouldn't it. And why would I have to change my obd. And i'm pretty sure I've already got obd2. And what upgrades should I get first. I'm thinking head work. Cams valves intake maifold etc.
As for doing a stock GSR swap, as long as its OBD2, u will only have to wire in vtec, knock and I think its a ground from vtec, not sure though ( I always forget that other wire) and since its OBD2 I think u have to wire in the crank position sensor, don't quote me on it, but they have a sub harness for you at www.rywire.com. All you will have to do is pin it into the ecu. Then get an OBD2 p72 ecu. And I would research the lengths of the exhaust manifold. I'm doing an OBD1 GSR swap into my 94 LS. Since I have an LS cat, I bought a DC header for a B16 or LS, since the GSR cats are longer and expensive. Hopefully some of this info helps you out, and I'm sure someone else might be able to cover something I missed. But again, I'm more familiar with OBD1.
it will ride
it will ride
And why would someone throw in a B17 into a 99 integra. And its pointless to put a cable tranny into the integra too. That is way to much work involved considering he is asking to do a simple swap. 99 integra is set up for hydro trans and the car is OBD2, (B17= OBD1).
ummm no i am not doing an ls/vtec swap....this link explains all. too many problems and its not that reliable...just read this link and you might be amazed
http://www.phatwhippincrx.20m.com/custom4.html
ls/vtec are reliable if done right and maintained. Just like any other engine...
There are TONS of reliable ls/vtec running around.. All motor and boosted as well. Don't get all your information from one article. You will be surprised how many "unreliable ls/vtecs" are running around.
yeah but with the budget im going to have, im not going to have enough money to do the ls/vtec complete build the right way. plus i will still have my ls motor that im taking out of my teg, so i can either sell it or rebuild it or whatever and just keep it, im not to sure yet.
but as far as the build goes, if i go gsr what parts or part of the motor would u suggest to build first and why?. im thinking i should start by building the head ( cams cam gears etc) or could i benefit from putting my money some where else first?
