Bad Rattle Please Help
Old May 16, 2010 | 01:54 PM
tweatybird74's Avatar
Default Bad Rattle Please Help
00PYT-0757
Car is making a loud rattling sound when starting off or going in reverse. This problme only happens when starting off, it does not occur when car is in motion. It seems to sound like its coming from the front right or directly underneath
Old May 17, 2010 | 07:20 AM
Tyrant_007's Avatar
Default Re: Bad Rattle Please Help
Has there been any maintenance or work of any kind done lately? If so, just make everything is torqued down properly. Aside from that, you'll just have to have someone help you track down where it is coming from. I know that bad motor mounts can make your entire car shake a little more and flush out anything not tightened down. <----can be very annoying!!! Good luck finding it.
Old May 17, 2010 | 08:44 AM
thanks for the suggestions. i have an appt tonight and i will get the motor mounts checked first> how do i know if they are shot ??
Old May 17, 2010 | 12:55 PM
follie gatts's Avatar
check the heat shields on your exhaust components. they will rust and break free from all but one or two of the mounting bolts and cause a rattle similar to the one you're describing. it's probably the shield above the cat.
Old May 17, 2010 | 01:08 PM
Dr. DC2's Avatar
Good luck. ITR's are just noisy.
Old May 17, 2010 | 01:29 PM
IanBlake's Avatar
lalocivic
Aug 13, 2009 10:04 PM
c 2
Aug 22, 2008 03:10 PM
starbury
Feb 14, 2005 08:35 AM
binkster
Jan 25, 2003 09:52 AM
redGSRguy
Mar 25, 2002 02:49 PM
