Bad week...Bent rod? b16 ef help please no oil
Old May 16, 2010 | 07:54 AM
nycpatron's Avatar
Icon2 Bad week...Bent rod? b16 ef help please no oil
Ok so I came back from a hour drive parked my car for a while normally no problems
night time comes and car is still driving normal I go for a drive and hit the gas a lil hard and I notice a weird sound coming from engine then my car starts to stall like if I stop hitting the gas the car would die...
take it home and the noise is louder so I automatically assumed I bent a rod or something
so I left it in my garage only took me about 5 mins to drive it home.
today I go to check the damage and first thing I check was the dipstick and guess what ...NO OIL at all...I did a oil change recently so I know it had oil in there.
So my question is what can cause this and would adding oil save it or how do I go into checking it or is it even savable any help would be appreciated thanks in advance.
Old May 16, 2010 | 10:05 AM
D16SiHatch's Avatar
Default Re: Bad week...Bent rod? b16 ef help please no oil
"what can cause this" - well it either burned out, leaked out, or a combination of both.
"will adding oil save it?" - no, adding oil is not going to bring it back to life. it sounds like you more than annihlated the bearings judging by what you've told me. most likely what you're hearing is rod and/or crank knock. its due to the lack of lubrication to the bearing surfaces.
"saveable?" sure it is, but not easy or cheap. you'll have to tear the engine apart and replace the main and rod bearings. if you're unluckier still you might also find yourself replacing the crank and possibly the rods. it all depends on if the bearings began to spin or not within the journals. if you know that the engine was burning oil prior then you might as well just do a complete overhaul of the engine. new bearings, rings, valve seals, everything.
Old May 16, 2010 | 12:00 PM
nycpatron's Avatar
I added some oil to it just now and just needs 1/2 a quart and the motor got better at idle theirs no knocking but if i rev it to 2000 rpm its there after adding the oil the car does not die at iddle.....
Old May 16, 2010 | 12:10 PM
mayfly's Avatar
did u bolt down the drain cap good? is it stripped? bad oil pan gasket. hitting crazy vtak to much yo. oil pump seal shitty? got pics?
Old May 16, 2010 | 12:16 PM
nycpatron's Avatar
drain cap is good and i guess it was not completely empty because when i added the 2 quarts it only needs 1/2 quart so im guessing it had 1 1/2 quart in there so i guess it just burned it i had 2 long trips this week but like i said it sounds better at iddle no sound at all but if i rev pass 2000 rpms it starts knocking ...sounds like if there was a couple of nuts inside the block
Old May 16, 2010 | 12:17 PM
nycpatron's Avatar
is there some test i can do to determine the ploblem if its rod or whatever
Old May 16, 2010 | 12:21 PM
teggi's Avatar
u should drop the oil pan and check for metal shavings and or broken parts
DCRB's Avatar
if it's knocking above 2k you have developed an early stage rod knock. i did teh exact same thing you did. went for hella drives and forgot to check my oil till my oil light kept comming on. added two quarts and it was just barely above the lower dot. i pulled it apart, several bearings were all thinned out and partially spun.
Old May 16, 2010 | 01:26 PM
nycpatron's Avatar
ill try that next thanks
Old May 16, 2010 | 01:27 PM
nycpatron's Avatar
what did you have to do?did u just replace the block or did u fix it?
Old May 16, 2010 | 06:02 PM
D16SiHatch's Avatar
so i'm assuming this goes without saying but i would not run the engine anymore to prevent further damage.
Old May 16, 2010 | 06:20 PM
blasterman87's Avatar
it would probably be cheaper to buy a new longblock. and i rod/crank bearings
Old May 16, 2010 | 06:27 PM
D16SiHatch's Avatar
to clarify. if you're not doing the work yourself it would definitely be cheaper to just purchase another longblock. now you might get away with just a shortblock but you will have to take the cams out and inspect the journals to see if they incurred any damage. if the head is alright then i would definitely just pick up or rebuild a bottom end.
Old May 16, 2010 | 09:47 PM
DCRB's Avatar
i chucked that piece of **** d15 in the garbage after i pulled my fly wheel off of it and rebuild my a6... dunno how it runs yet, my income is tiny so my build is slow as fak lol
Old May 17, 2010 | 04:00 PM
nycpatron's Avatar
I took off my rod bearings and they were broken on the edge, crank feels and looks like there was no damage ill be replacing them tomorrow i think I am pretty sure once i change them it will be ok because it didnt look that bad and it was pretty easy also not that hard took me like an hour to drop the headers oil pain crank guard and then the bottom part of the rod and this was my first time doing that too...
Old May 17, 2010 | 08:13 PM
D16SiHatch's Avatar
before you put it back together i would definitely check the rod and crank journal clearances with a micrometer.
jaywoodz
Feb 5, 2007 09:24 AM
io_burn
Jan 5, 2003 10:19 AM
94thundergrey
Nov 12, 2002 12:55 PM
PY2KITR1060
May 4, 2002 01:30 PM
