!998 GSR Swap EK No Spark HELP!!!!
I have a 1998 gsr swaped ek ran fine just died one day when it was idling in the street. What i have done it trouble shoot it i have replaced the hactacular harness that came in the car with a ex harness that was converted to work with the gsr. 3 ecus i am running obd2a-obd1 jumper and tried a chipped p30, p72, and a obd2a P2P n change and also tried 3 obd1 b-series vtec distys. Sanded and checked all grounds for good continuity. I am at a loss I just don't know what to do besides throw a molotov cocktail at
it. Only thing and i'm not 100% sure if it effects spark is the main fuel relay. I'm not new to hondas just never post here just had to suck it up and ask for help.
I bet if you try a diffrent dizzy it will work the ignition coil maybe went bad happened to me before. so get a coil pack or diffrent dizzy
Plz read thoroughly i know all 3 Distys are good they will start other cars not talking **** just keep getting told that and i have tested them with my volt meter.
Ok so replaced my disty jumper and got spark still no fire checked fuel not getting fuel so ends up I'm out of fuel, gas gauge stopped working cuz of a loose harness for that side of the cluster FAIL... DAM gremilins all this hit at once!
Thanks for all the help Dick
xdustin513x
Nov 21, 2008 03:07 PM
