Integra 1997 Throttle Cable Issue
Old May 15, 2010 | 04:38 PM
kelviiv's Avatar
Default Integra 1997 Throttle Cable Issue
Hello
I am having an issue with my throttle cable issue. Right now everytime I push down the throttle cable the cable goes out of place. I have adjusted it for the past 2 hours and can't find the right position. I also looked at another LS and adjusted it to the same threading. I don't know what the issue is right now but I do not feel safe driving the car if the throttle cable keeps on coming out.
Please help thank you
the vehicle is an automatic
Old May 15, 2010 | 05:24 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Integra 1997 Throttle Cable Issue
What do you mean by "coming out"? Like it's coming off of the mount bracket? Can you take a close-up picture of the cable area around the bracket and where it connects to the TB?
Old May 15, 2010 | 07:22 PM
kelviiv's Avatar
Sure thing, and yes I mean it is coming out of the metal bracket =X
Old May 16, 2010 | 07:26 AM
fcm's Avatar
fcm
Old Fart
Sounds like inner cable is "sticking", either because it is "dry" or there is a "kink" in the outer cable.
Confirm this by turning the TB linkage by hand and seeing if inner cable is pulled back into outer cable when TB linkage is released, if not, replace throttle cable.94
Old May 20, 2010 | 05:36 PM
kelviiv's Avatar
Ok, will any LS throttle cable work from 94-01?
Also does anyone have a write up on how to remove the throttle cable,
Thank You
Mixmasta
Jul 14, 2008 06:30 AM
SohcVtaak
Sep 13, 2007 08:34 AM
