Front end suspension Question??
Old May 15, 2010 | 07:21 AM
Black Diamond's Avatar
Default Front end suspension Question??
This might be an easy fix but i need to ask it..I have a 94 ej1 and when you get up to about 70-80 Mph the front end starts to get a little floaty..Is that because its a front wheel drive car? Or do i need some kind suspenion parts to help this.Im currently on stock suspension but in about 2 weeks it will be getting FF type ones, Function 7 lca's, and a ASR rear brace..Will this help the Floating problem i am experiancing in the Front?
LMK Honda-tech
Thanks, NICK
Old May 15, 2010 | 07:28 AM
jdmh22eg2's Avatar
Default Re: Front end suspension Question??
it is just the nature of eg chassis and most 4cly fwd cars my girls moms fit gets uber scary at 85-90
the only thing u listed that will help floating is the type 1's only cause u can lower center of gravity down other stuff unless u are xcrossing or road racing is a waist on the street
Old May 15, 2010 | 07:35 AM
Cool, and the other stuff is for looks..
Old May 15, 2010 | 07:38 AM
jdmh22eg2's Avatar
yea it is i personally dont see a need for 3-400 in looks i would rather put money else were it matters IMO
Old May 15, 2010 | 07:42 AM
I know but im not spending 300 and im not spending 200 my buddy is hooking me up..
Hopefully the coilovers will help with the floating problem!
Old May 15, 2010 | 07:46 AM
jdmh22eg2's Avatar
yea idk how u are on dumped or not but if not then just put a touch over the tire and should go away till about 125mph or so give or take
i do chassis work for side work on a road race car only reason i know the area and mph
Old May 15, 2010 | 10:24 AM
98civdx's Avatar
Master Detailer
my friends eg did this, replaced inner and out tie rods, upper lower ball joints and alignment it felt way better.
Old May 16, 2010 | 09:08 AM
Cool thanks thats what i was planning for..i am going to do the Coilovers first and see if that helps and if not start with tie rods and such..
Thanks!
Old May 16, 2010 | 10:14 AM
thumper64's Avatar
Lowering it and putting better suspension on will help. There's aerodynamic stuff you could do too, but that's not necessary.
Old May 16, 2010 | 10:42 AM
98civdx's Avatar
Master Detailer
No problem, however it were me, i would do them now, on a 94 they are most likely worn, my 98's are beat to ****, lower it, tie rods, ball joint and get it aligned.
Old May 17, 2010 | 05:52 AM
ek747's Avatar
Mine does this as well and I think I need to change by track rod ends.
Old May 17, 2010 | 10:27 AM
98civdx's Avatar
Master Detailer
^You mean tie rod end?
Old May 18, 2010 | 06:15 AM
ek747's Avatar
I guess there the same thing, although that's what we call them in the UK.
Historyg
Suspension & Brakes
Oct 16, 2007 10:27 AM
Historyg
Oct 15, 2007 11:46 PM
EJ1_manG
Suspension & Brakes
Feb 8, 2007 12:21 AM
Janeshonda
Suspension & Brakes
Aug 23, 2006 10:13 AM
