turbo rex not starting
sounds like the main relay.... its under the dash next to the fuse box.... im not on my computor now or else i could post a pick..... open ur fuel door and put ur ear to thefuel fill tube and c if ur pump is workin.... if it is not check the fuse.... but it sounds like the main relay to me.... can someone help with the relay location
i have like half tank but i can hear my fuel pump but it just sounds funny like ive had a couple hondas and i know how it sounds when it primes but on this it just sounds funny bad pump or need new filter ?
ok so your car aint starting but we dont know **** about it. what motor, what chassis, what ecu, what dizzy your running, are all your wires sealed and not naked, DID you convert, WAS or IS your car oem mpfi or dpfi?
gotta give us some more info dude
i have a crx with a b18c5 umm a obdo ls dizzy obd1 injectors and a chipped pw0 ecu and for my ground wires they are pretty small its a si so its stock mpfi and all my wires are covered
what ever year the head is, you have to have the same year or equivilant dizzy. the ecu is able to get modded to accept that platforms requirements but the dizzy has different internals than a vtec ecu
si90rex
Jun 24, 2007 05:53 PM
